Aether Reverb
I was going to add a reverb to Mutated Instruments when I realized my favorite reverb plugin is already open source. All I had to do was fix up the TTL a little,build for arm64, and here we are. About 50 controls (I think 47) to tweak your reverb to your hearts content.
https://github.com/PatttF/zynMI/releases/download/BraidsPlaitsMarbles/Aether-arm64.zip
Cool, I’ll try that. There was also appearing this one lately:
It’s also based on Cloudseed.
Oh wow, that looks great, I’m going to check it out, it might even be better than this. This is just what I’ve been using for a long time.
Hi @PatF !
I see you included all your plugins (5 in total) in the “zynMI.zip”, so no need to create separated install scripts, right?
Archive:  zynMI.zip
   creating: mi_aether.lv2/
  inflating: mi_aether.lv2/aether.so
  inflating: mi_aether.lv2/aether.ttl
  inflating: mi_aether.lv2/manifest.ttl
   creating: mi_braids.lv2/
  inflating: mi_braids.lv2/braids.so
  inflating: mi_braids.lv2/braids.ttl
  inflating: mi_braids.lv2/manifest.ttl
   creating: mi_marbles.lv2/
  inflating: mi_marbles.lv2/manifest.ttl
  inflating: mi_marbles.lv2/marbles.so
  inflating: mi_marbles.lv2/marbles.ttl
   creating: mi_mutated.lv2/
  inflating: mi_mutated.lv2/manifest.ttl
  inflating: mi_mutated.lv2/mutated.so
  inflating: mi_mutated.lv2/mutated.ttl
   creating: mi_plaits.lv2/
  inflating: mi_plaits.lv2/manifest.ttl
  inflating: mi_plaits.lv2/plaits.so
  inflating: mi_plaits.lv2/plaits.ttl
BTW, those wanting to install or update the ever-growing “MI” plugin collection by @PatF, simply run this from the command line:
$ZYNTHIAN_RECIPE_DIR/install_zynMI_prebuilt.sh
regenerate_engines_db.sh
I’ve not added this to the update system, awaiting for the collection to stabilize, but it’s growing very fast, jejeje! Great work, @PatF !
Thanks a lot!
Oaooo! I just tested the Aether reverb and i must say it sounds really great! And @PatF did a fantastic work with the TTL, grouping and ordering the parameters, so it’s really a pleasure to use it. It’s a strong candidate to be enabled by default in the next release :wink:
Thanks @PatF!
No what you have should work great. I’ll just keep the same tags and file names like I have been. I put them all in zynMI but also have the individual downloads as well.
Thanks. I just want to give back with things I love too.
