Well 2020 being what it is, I haven’t been on my Zynthian or music machines at all for many months. Today I fired up my Zynthian v3 and figure I should do the software update. The update seemed to go okay and in fact finished and booted back to the normal Zynthian UI. However, shortly after that I requested a reboot from the UI. It rebooted, but then went into a loop where the screen turns white for about 30 seconds and then flashes off and the whole process repeats indefinitely. I can get to the webconfig and that remains connected even while the screen goes through it’s flashing cycles. Here is the debug output that seems to just repeat.
If I force a reboot or shutdown from the webconfig, then it will come up and show the Zythian logo on the next power up, before going into the white screen flashing loop.
It looks like the update lost track of some files. Any ideas how I can get it running again without blowing everything out?
Thanks,
Scott
Restarting UI in debug mode
– Logs begin at Thu 2019-02-14 10:11:59 GMT. –
Dec 06 17:14:29 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Dec 06 17:14:29 zynthian startx[15934]: X.Org X Server 1.20.4
Dec 06 17:14:29 zynthian startx[15934]: X Protocol Version 11, Revision 0
Dec 06 17:14:29 zynthian startx[15934]: Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Dec 06 17:14:29 zynthian startx[15934]: Current Operating System: Linux zynthian 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l
Dec 06 17:14:29 zynthian startx[15934]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Dec 06 17:14:29 zynthian startx[15934]: Build Date: 05 June 2019 12:49:54PM
Dec 06 17:14:29 zynthian startx[15934]: xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Dec 06 17:14:29 zynthian startx[15934]: Current version of pixman: 0.36.0
Dec 06 17:14:29 zynthian startx[15934]: Before reporting problems, check http://wiki.x.org
Dec 06 17:14:29 zynthian startx[15934]: to make sure that you have the latest version.
Dec 06 17:14:29 zynthian startx[15934]: Markers: (–) probed, (**) from config file, (==) default setting,
Dec 06 17:14:29 zynthian startx[15934]: (++) from command line, (!!) notice, (II) informational,
Dec 06 17:14:29 zynthian startx[15934]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Dec 06 17:14:29 zynthian startx[15934]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Dec 6 17:14:29 2020
Dec 06 17:14:29 zynthian startx[15934]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Dec 06 17:14:29 zynthian startx[15934]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Dec 06 17:14:30 zynthian startx[15934]: INFO:zynthian_gui_config.: ZYNTHIAN-UI CONFIG …
Dec 06 17:14:31 zynthian startx[15934]: INFO:zynthian_gui_config.: Wiring Layout MCP23017_ZynScreen
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.: ZYNCODER A: [102, 105, 110, 113]
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.: ZYNCODER B: [101, 104, 109, 112]
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.: SWITCHES layout: [100, 103, 108, 111, 106, 107, 114, 115]
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = [’’]
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’]
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = [’’]
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 32
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: 12517503
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: 12517376
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: 13598464
Dec 06 17:14:31 zynthian startx[15934]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: 13565952
Dec 06 17:14:31 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)…
Dec 06 17:14:31 zynthian startx[15934]: Terminated
Dec 06 17:14:31 zynthian startx[15934]: identify-im6.q16: unable to open image /zynthian/config/img/fb_zynthian_error.png': No such file or directory @ error/blob.c/OpenBlob/2874. Dec 06 17:14:31 zynthian startx[15934]: identify-im6.q16: unable to open image
/zynthian/config/img/fb_zynthian_error.png’: No such file or directory @ error/blob.c/OpenBlob/2874.
Dec 06 17:14:31 zynthian startx[15934]: expr: syntax error: unexpected argument ‘100’
Dec 06 17:14:31 zynthian startx[15934]: expr: syntax error: unexpected argument ‘24’
Dec 06 17:14:31 zynthian startx[15934]: convert-im6.q16: invalid argument for option `-pointsize’: -fill @ error/convert.c/ConvertImageCommand/2359.
Dec 06 17:14:31 zynthian startx[15934]: /zynthian/config/img/fb_zynthian_error_ip.png: image not found
Dec 06 17:14:31 zynthian startx[15934]: didn’t find evidence of prior run.
Dec 06 17:14:31 zynthian startx[15934]: Building XImage…done
It basically repeats this whole sequence over and over.
