ALSA ADC level extremely high
I’m experiencing a problem with adding an audio chain.
The input gain is extremely high so even without signal the static sounds very loud.
I found out this is caused by the ALSA gain setting. By default it is set to 100 (40.00 dB gain). This is far and far too much for normal use.
I can dial this back to an acceptable level ( 0.00 dB gain) with alsamixer but this is not saved, not even when I use alsactl store. After a reboot the gain is back again at 40dB.
Does anyone else see this same behaviour? Or know what can be done about this? Of course I can try to add an amixer command during startup, but perhaps there is a better way.
This happens on both my V5.1 kit and on my V5 clone.
Kind regards,
Hans.
No need - it should already be integrated in zynthian. Go to “Audio Levels”, e.g. by pressing the “MIX | LEVEL” button (toggles between mixer and audio levels views) then change the level there. This should be saved with a snapshot if “Audio Levels on Snapshots” is enabled in admin menu.
Great! Thanks @riban !
This recipe works for ORAM. I have not tested it in Vangelis (it has different snapshot format)
For those in the same boat as me who want to replace the unworkable, high default gain values ​​in all snapshots for neutral ones, you can use the following command.
Go to the snapshots directory
cd /zynthian/zynthian-my-data/snapshots
Make backup of current directory (for safety)
cp -R 000/ 000B/
go to current directory
cd 000
Replace all 40dB input gain settings with 0dB settings
sed -i "s/\"PGA_Gain_Left\": {\"value\": 104}, \"PGA_Gain_Right\": {\"value\": 104},/\"PGA_Gain_Left\": {\"value\": 24}, \"PGA_Gain_Right\": {\"value\": 24},/g" *.zss
(this is all on one line).
If you have multiple snapshot directories, repeat for all.
EDIT:
If you also want the output volume limited to 50% you can use this:
sed -i "s/\"Digital_0\": {\"value\": 207}, \"Digital_1\": {\"value\": 207},/\"Digital_0\": {\"value\": 157}, \"Digital_1\": {\"value\": 157},/g" *.zss
Both commands work only for HifiBerry (sndrpihifiberry) audio.
Kind regards,
Hans.
Thanks for sharing, it is unclear to me if a structural fix is recommended for this and/or an issue should be logged.
Perhaps, but there will be no fixes for Oram so this is the only way to solve issues like this.
