An issue using Note to CC effecct
So I’ve set up sooperlooper, and I have a midi controller that outputs buttons as notes, I tried to turn the notes into CC, but I still can’t learn on it, I’m assuming learning is in the UI stack… Is there any plans on making midi notes learnable? the ableton behavior is pretty good for that… when you learn a midi note it stops playing the note, but that can be manually set up by filtering too
