An open source hardware design for type A (or standard nowadays) and B midiTRS in to serial adapter
Just stumbled upon this, the genius of it is amaizing.
Basically its a midiTRS in to serial circuit with optocouplers that supports both standards without switches or anything
Excellent, Nice catch.
Where is the same for MIDI out ?
I’m not sure that’s doable at all like this, “automagically”, however with a double pole switch you can easily achieve that i think
Here an explanation MIDI to TRS adapter with A/B switch – ranzee
In this reddit thread
MIDI out is easy if you have two UARTs available. Wire so TX on both UARTs goes to the midi output pins. Then you can enable / disable the UARTs via software.
so with the pi 4 and 5 this is probably fully feasible
