Anyone here used https://processing.org/?
I’m trying to put together an arduino oscilloscope for MIDI cc a’la…
https://www.build-electronic-circuits.com/arduino-oscilloscope/
Can’t get the MIDI library recognised in the app on Pi64 … Even thou’ I’m pretty sure the library
https://github.com/sparks/themidibus?tab=readme-ov-file is as it should be…
I have stopped using midi libraries. They always have some limitations. I simple use serial protocol library with correct speed for midi and midi data format. Although I do this on esp32 using arduino framework not on rpi.
Oooh which are…?
Serial speed for MIDI is 31250.
I use Arduino SoftwareSerial library.
MIDI data format is simple. Check my header and class file how I connect and send note on and note off.
Thanks for that.
