Are multiple Pianoteq Instances possible?
I fear, I already know the answer – But still, is there a way to have Pianoteq on two different chains? If I, for example, need a nice Piano AND a nice Rhodes the same Project?
Pianoteq always disappears from the list of sound generators, the moment it is in use in another chain…
Pianoteq is one of our engines that may only be added once, sorry!
Longer answer: use zs3 to quickly switch between two presets.
Also, in pianoteq gui, you can create a layered instrument (of two iirc). Which you can then load as a preset.
Two independent chains are impossible though.
