Hi everyone again. Yesterday I managed (with your help, of course) to make it work with AudioInjector Zero and for the moment, a cheap 3,5 screen. While I’m waiting for the controller board and the encoders to arrive I’m trying all the capabilities of this magic device.
I noticed you can enable aubionotes, and config from the Webconf. If I plug my guitar (to an amp and through line output) to the input, I can hear it, but I can’t figure if it’s possible with aubionotes to convert it to midi notes and trigger the Zynthian sounds. Or do I need to config anything else?
I’ve not really had too much success using Aubionotes but I haven’t given it too much attention. I’ve had it doing strange things when Ive turned it on accidentally…
I think the ZynMixer branch won’t help you on this. You better try with the ALSA Mixer. You can configure the controls from the webconf Hardware Audio tab.
Ok, I’ll leave that rest for now and put it somewhere on my longterm agenda. Trying to do a lot of things at the same time which is generally not a good idea. But this box is definitely opening up opportunities!
You can enable Aubionotes in the MIDI Input menu in Admin and bold press to select which audio inputs feed aubionotes. (I am about to change how this config is done but for now - this is the way to do it.)
Aubionotes does not lock to audio below around B2 and it will give some false triggers but it can be fun to play with. I don’t think I would trust it for live performance.
[Edit] I have just changed this so that enable/disable aubionotes is now done with the “Audio2MIDI” entry in the MIDI section of the Admin menu . You can select the audio inputs to aubionotes by bold press on it in a chain’s MIDI In menu (reached from the chain options menu).
[Edit] Ah! It has reverted. Enable/disable Aubionotes (Audio2MIDI) is in the MIDI Input submenu of Admin menu. Select audio inputs also there (bold press) as well as the MIDI In submenu of Chain Options.
