today first try to record audio with the zynthian v3
for audio out is working on the jack connectors.
no audio out on the cinch day.
have I missed something in the manual?
should both work the same time or do if have to set out and in routing first somewhere else?
OK! You mean the RCA connectors … i didn’t know the word “cinch”, but i just read in the wikipedia that it’s used in some countries …
The RCA should work out the box. They are electrically connected to the output Jack connectors, being the the same signal exactly, so you could test for continuity with a multimeter pin by pin.
Also, I would check the cable or the RCA input on your amp.
By default, audio input is not routed to the output. You have to create a FX layer to do so. If you don’t want any FX, simply add a Gain.
Also, take a look to the levels on the ALSA Mixer. For recording from the minijack, you should be using “VNL_1” and “VNR_1” for the ADC input selection. If you were using the Balanced Input, then you have to use the last option (DIFF).
