Available CS80 like ribbon...?
Any one know if you can get beasts like the cs80 ribbons as components?
Is there a sub sub culture out there?
I have seen this kind of thing built as a DIY project using conductive plastic (velostat), like this. Maybe a subject for a hackathon?
If you’re just after the linear position sensor, I can recommend the Spectra Symbol ā€œThinPotā€ devices. Use them as you would a potentiometer. They come in a range of lengths, I’ve used the 500mm parts ( TSP-L-0500-203-3%-ST) for ribbon controllers before. I usually get them from Digikey, though they are not cheap. You can save about 20% by opting for 3% linearity rather than the more accurate 1%; also the solder-tab option rather than pin connectors. Here is the part on my local Digikey site.
For added fun and enjoyment you can combine the position sensor with a 500mm FSR pressure sensor like this one. With this combination you can control two parameters at once, for example: pitch and volume.
For a more complete unit, Doepfer make a MIDI ribbon controller that includes both position and pressure. There is an option to buy just the sensor if you want to do your own electronics.
Hope this helps!
For some inspiration, check out Martin Molin’s ā€œModulinā€ which uses the Doepfer ribbon module:
He explains the workings here:
Why thank you @stewart.
You are off rook soup for a week!!
https://www.mouser.co.uk/ProductDetail/Spectra-Symbol/SP-L-0500-203-3-ST?qs=rVuZtzXoae5/ClXxQbhQtw%3D%3D
I wanted to point to this topic, as well as DIY ribboncontroller in response.
In a lot of ways, I think Artiphon Chorda, Chorda - Wikipedia , when used as a MIDI controller, is very much like the CS80 Ribbon, but on the other hand, I’ve never played an actual CS80.
And of course a lot would depend on what you want to DIY, and what you want to buy, and what you just want.
edit: oops - Google Search on chorda+artiphon , wikipedia is for the marine algae, which though interesting, doesn’t seem particularly relevant.
Thanks @tunagenes ,
I’ve seen the Chorda before and it’s certainly an interesting device, but for me the fun is more in making it than in owning it.
Kind regards,
Hans.
