I just downloaded the last version of the zynthian RC3, but i don’t know if this problem is related to this specific version.
When i sent midi information (cc, note…), i hear all the times clicks, even if i use zynthian knobs.
I made a video to show you, even without sounds from plugins i can hear clicks !
I use a 3A power supply, so i don’t think it’s come from that.
Any solutions ?
EDIT :
I partially solved the problem, I removed a audio effect layer and lower the input volume in alsa mixer, and no more clicks, but it’s strange because nothing it’s pluck into my audio input.
So I think it’s not a good idea to use lv2 synth layer and audio input effect layer in the same time.
Do you know where the problem come from ? Thanks !
Anyway, it smells like a power supply problem. The USB power cable is very important too. You can have the best power supply, but if your cable is not good enough, you will have problems.
I just made a video to explain my issue.
I voluntary put the volume in a very loud way to better understanding. I know we never put the volume at this point but when I put some midi in the zynthian i can hear the clicks even when the sound volume it’s normal.
my problem is : when i add audio fx layer, it’s create midi clicks in my synth layer, without audio fx layer, no more clicks.
Do you think it’s my power supply or something else ?
