Edgar is saying that after finishing the 5.1 kit build after turning it on everything seemed to work.
But today after switching it on “nothing works, only the lady appears”
which I would interpret as seeing the Oram splash screen with nothing more happening.
This is all the information Edgar provided, let’s hope that if he doesn’t speak english he uses google translate to understand the replies.
Edgar, can you ssh into the Zynthian when it hangs? Is the webconf interface reachable?
Could you say what SD-card brand and model are you using? This is really important.
SD-card issues are the more frequent cause of boot issues. This is largely discussed in other threads and also warned and explained along the wiki tutorials.
Also, if you could access the webconf tool and send the logs, it would help to diagnose your problem.
Hi Jofemodo,
I think I have found the reason of troubles, it is again the ffc-Connektor on the mainboard (CONTROL -1). I fixed new all the other connectors and I could see some Instruments on the screen. But the connector Control-1 lost the securing and so I cant fix the Cable in the secure position. What can I do?
Edgar
Do you mean you broke the CONTROL-1 connector’s tongue while building your zynthian?
OK! Sometimes it could happen …
You could buy some FPC connectors from Mouser or Digikey and try to replace the tongue. Replacing the tongue is possible, but i recommend you buy a bunch of connectors to have enough tongues to try
Alternately, you could try securing the broken connector with hot glue. It’s not nice but it normally works if done with care.
Anyway, i recommend you use a decent magnifying glass for manipulating these connectors. Good lighting, good tools, a large, stable and well addressed work table. Stay relaxed and have enough time. Hurry doesn’t help with this kind of operations. Doing my “yoga” before, works for me!
Hi Jofemodo,
I think that I could solve the Problem. I fixed all the cables with a tape and now it works. I think, that also the USB-Connektor was not locked deap enough and I also fixed it . Perhaps I will ad some hot glue to the Ctr. Connektor
Good to know you managed to solve the issues.
Please, ensure the tape is good quality and it’s going to last. If not sure, hot glue will last for many years.
