What would be the best bass guitar like sound I could get on the Zynthian for rock?
Roger Waters bass would be what I’d be inclined for it to sound like.
Selecting a sound for an engine can be done by pressing back from the paramer page for that engine. The sound will previ
Ew as you select different patches if you press a key.
That is the technique I use to choose a sound, but the most flexible mechanism is to combine two differing patches using MIDI clone as this allows you to balance between two sounds to refine the final result.
If you want an electric bass guitar sound you will probably want to use a sample in Linux Sampler, Sfizz or Fluidsynth. There are several bass guitar sounds too choose from.
