Booting straight in to mixer
When I turn my Zynthian on it boots straight in to mixer screen. From that point on I have to press top left encoder for 3 seconds to get out of there. Then I need to press bottom left encoder to get to where I want to be. I want to boot in to the screen where I can add instruments instead of the mixer. Is this possible and if so how would I do that? Thank you!!!
Adding chains is a configuration. Once you have configured the device the mixer is a good place to be. It acts as the “home” screen from where you can quickly access most common functions. I don’t recognise the workflow you describe. Bold press top left encoder takes you to the menu where you can add new chains. It sounds like you are long pressing which takes you to admin menu.
Check out the user guide on the wiki which had navigation diagrams.
