I’m figuring out the Jackd settings for various audio interfaces I have around like my old Lexicon (actually Digitech) Alpha. I’d like to add these to the sound card drop-down menu of Zynthian so I don’t have to type in the details manually when switching. I assume there is a system file I can edit that has these definitions in it.
I’m testing some additional Interface settings on this Python page. The JACKD_OPTIONS settings are fairly easy to understand and setup but I don’t know how the input and output names are determined for some of the interfaces like the HiFiBerry for instance.
‘SOUNDCARD_MIXER’: ‘Digital Left,ADC Left,Digital Right,ADC Right,ADC Left Input,ADC Right Input’
Anybody know how I can find a list of inputs and outputs for a given audio interface or the names for them? Maybe these are just arbitrary names assigned to a list of I/O points?
You can use in a terminal (ssh or through webconf built in terminal) the alsamixer command.
It will show you the alvailable hardware controls (if any) in the Alsa sound system layer.
