Hi
I am just getting started on a box and would like to use the InnoMaker Rasp Pi HiFi DAC Hat PCM5122 I have, But I can’t see the device in the hardware->Audio-Soundcard section. Is there a way to get this going?
Hi
Simply select some other device that uses same/similar chip. HifiBerry DAC+ could be a good starting point ![]()
Hi
From here
Dac must been set as AlloBoss but there’s no entry in zynthian webconf
So documentation in:
they say: dtoverlay=allo-bossdac-pcm512x-audio
and the alsa hardware name should be BossDAC (to be used in Jackd hw:BossDAC parameter)
While using the same hardware as ZynADAC or HifiBerry ADAC, the InnoMaker has differents clocks for their XTALs.
Hi, Bendy!
I use exactly the same sound card and it works. If you need nuances for setting up a sound card, Let me know in this thread. I can only answer on Sunday evening, because now I’m away and I don’t have any equipment with me.
Yes, it works, but it took some time to get it working. The following might help: InnoMaker Raspberry Pi HiFi DAC HAT PCM5122
