I have a problem adding any effect (delay, reverb or similar) to chain or master.
When I try to add any effect I get on error on the screen :
CUIA zynswitch failed with params: (27, 'S')
Here is the log :
Jun 04 23:45:20 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 27
Jun 04 23:45:20 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'V5_ZYNPOT_SWITCH' => [3, 'S']
Jun 04 23:45:20 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Jun 04 23:45:20 zynthian startx[1482]: DEBUG:zynthian_gui_engine.get_engines_by_cat: CATEGORIES => ['Delay', 'Distortion', 'Dynamics', 'Filter & EQ', 'Modulation', 'Panning & Spatial', 'Pitch', 'Reverb', 'Amplifier', 'Analyzer', 'Other']
Jun 04 23:45:20 zynthian startx[1482]: INFO:zynthian_gui_engine.update_info: Can't get info for engine 'None'
Jun 04 23:45:24 zynthian startx[1482]: INFO:zynthian_gui_engine.update_info: Can't get info for engine 'None'
Jun 04 23:45:40 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 27
Jun 04 23:45:40 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'V5_ZYNPOT_SWITCH' => [3, 'S']
Jun 04 23:45:40 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Jun 04 23:45:40 zynthian startx[1482]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/DS1' with ID '5'
Jun 04 23:45:40 zynthian startx[1482]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => DS1-01
Jun 04 23:45:40 zynthian startx[1482]: INFO:zynthian_engine.start: Starting Engine Jalv/DS1
Jun 04 23:45:40 zynthian startx[1482]: DEBUG:zynthian_engine.start: Command: jalv -n DS1-01 http://moddevices.com/plugins/mod-devel/DS1
Jun 04 23:45:41 zynthian startx[1482]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => DS1-01
Jun 04 23:45:41 zynthian startx[1482]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Jun 04 23:45:41 zynthian startx[1482]: ERROR:zynthian_gui.cuia_thread_task: CUIA zynswitch failed with params: (27, 'S')
After that if I do anything on UI it just freezes (zynseq is still playing) and I need to restart it through webconf-ui.
It looks like jackd is screwed - this is in the log if I try to remove chain after adding the effect.
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1675, in custom_switch_ui_action
Jun 04 23:45:41 zynthian startx[1482]: self.callable_ui_action_params(cuia)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1027, in callable_ui_action_params
Jun 04 23:45:41 zynthian startx[1482]: self.callable_ui_action(cuia, params)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1013, in callable_ui_action
Jun 04 23:45:41 zynthian startx[1482]: cuia_func(params)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1540, in cuia_v5_zynpot_switch
Jun 04 23:45:41 zynthian startx[1482]: self.zynswitch_short(i)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1907, in zynswitch_short
Jun 04 23:45:41 zynthian startx[1482]: self.screens[self.current_screen].switch_select('S')
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui_selector.py", line 346, in switch_select
Jun 04 23:45:41 zynthian startx[1482]: self.click_listbox(None, t)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui_selector.py", line 337, in click_listbox
Jun 04 23:45:41 zynthian startx[1482]: self.select_action(self.index, t)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui_engine.py", line 356, in select_action
Jun 04 23:45:41 zynthian startx[1482]: self.zyngui.modify_chain()
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 823, in modify_chain
Jun 04 23:45:41 zynthian startx[1482]: processor = self.chain_manager.add_processor(self.modify_chain_status["chain_id"], self.modify_chain_status["engine"], parallel=parallel, post_fader=post_fader)
Jun 04 23:45:41 zynthian startx[1482]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zyngine/zynthian_chain_manager.py", line 791, in add_processor
Jun 04 23:45:41 zynthian startx[1482]: zynautoconnect.request_midi_connect(fast_refresh)
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zynautoconnect/zynthian_autoconnect.py", line 365, in request_midi_connect
Jun 04 23:45:41 zynthian startx[1482]: midi_autoconnect()
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/zynthian-ui/zynautoconnect/zynthian_autoconnect.py", line 592, in midi_autoconnect
Jun 04 23:45:41 zynthian startx[1482]: dst_ports = [jclient.get_port_by_name(re.escape(dst_name))]
Jun 04 23:45:41 zynthian startx[1482]: File "/zynthian/venv/lib/python3.11/site-packages/jack.py", line 1533, in get_port_by_name
Jun 04 23:45:41 zynthian startx[1482]: raise JackError(f'Port {name!r} not available')
Jun 04 23:45:41 zynthian startx[1482]: jack.JackError: Port 'DS1\\-01' not available
Jun 04 23:45:44 zynthian startx[1482]: DEBUG:zynthian_gui.close_screen: SCREEN HISTORY => ['audio_mixer', 'chain_options', 'engine']
Jun 04 23:45:44 zynthian startx[1482]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'loading' => Back to 'engine'
Jun 04 23:45:44 zynthian startx[1482]: DEBUG:zynthian_gui_engine.get_engines_by_cat: CATEGORIES => ['Delay', 'Distortion', 'Dynamics', 'Filter & EQ', 'Modulation', 'Panning & Spatial', 'Pitch', 'Reverb', 'Amplifier', 'Analyzer', 'Other']
Jun 04 23:47:10 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 5
Jun 04 23:47:10 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'SCREEN_AUDIO_MIXER' => None
Jun 04 23:47:15 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_bold: Bold Switch 27
Jun 04 23:47:15 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'V5_ZYNPOT_SWITCH' => [3, 'B']
Jun 04 23:47:15 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_bold: Bold Switch 3
Jun 04 23:47:29 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 5
Jun 04 23:47:29 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'SCREEN_AUDIO_MIXER' => None
Jun 04 23:47:31 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_bold: Bold Switch 27
Jun 04 23:47:31 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'V5_ZYNPOT_SWITCH' => [3, 'B']
Jun 04 23:47:31 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_bold: Bold Switch 3
Jun 04 23:47:36 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 27
Jun 04 23:47:36 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'V5_ZYNPOT_SWITCH' => [3, 'S']
Jun 04 23:47:36 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Jun 04 23:47:40 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 27
Jun 04 23:47:40 zynthian startx[1482]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'V5_ZYNPOT_SWITCH' => [3, 'S']
Jun 04 23:47:40 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Jun 04 23:47:40 zynthian startx[1482]: DEBUG:zynthian_gui.close_screen: SCREEN HISTORY => ['engine', 'audio_mixer', 'chain_options', 'option']
Jun 04 23:47:40 zynthian startx[1482]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'option' => Back to 'chain_options'
Jun 04 23:47:41 zynthian startx[1482]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Jun 04 23:47:41 zynthian startx[1482]: INFO:zynthian_gui_confirm.switch_select: callback None
Jun 04 23:47:41 zynthian startx[1482]: DEBUG:zynthian_gui.close_screen: SCREEN HISTORY => ['engine', 'audio_mixer', 'chain_options']
Jun 04 23:47:41 zynthian startx[1482]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'confirm' => Back to 'chain_options'
Jun 04 23:47:41 zynthian startx[1482]: DEBUG:zynthian_chain.remove_processor: Removing processor sfizz-01
Jun 04 23:48:11 zynthian startx[1482]: WARNING:zynthian_gui.busy_thread_task: Clients have been busy for longer than 30s: {'remove_chain', 'remove_pro
Is this bug ? Should I raise a ticket ?
