When I try to set a Trigger note for a pad inside sequencer using encoder and then clicking to save it it is always saved a half note higher than what is selected. If you do the same but use MIDI controller (e.g. keyboard) to select a trigger note and not encoder it is properly saved.
Can somebody check that this is a bug and not something wrong with my encoder wiring which I suspect is not the case ?
I confirm there was an issue with trigger note being +1. This is now fixed (as well as some issues with MIDI learn of trigger note). Please update Oram.
I am on latest Oram Release with Zynthian v5.1. It seems that saving and/or restoring trigger notes and devices to fire Zynthpads is not reliable. When starting Zynthian and loading snapshots, sometimes trigger notes and/or devices are not restored correctly. And I can remember, that the situation was the same 1/2 year ago or so.
