My keyboards sends PCh-Comands with leading LSB and MSB.
I tried to send such commands, but the Zynthian doesn´t get the commands.
Using WebConf MidiLog:
Not under Midi IN, neither using Impulse In, neither using ZynMidiRouter Main.
And I cannot update the system. I think it´s closed.
and then send a PCh-Command with the correct programnumber.
Thanks for your faboulos work. Please excuse my faults by using this work area and github too. English is not my language, but I love, what we are doing here.
What SD-image are you using? Gorgona is completely outdated. Please, update to Aruk RC-3 or Buster RC-1. Ahh! And don’t forget to update the software after first boot
And show is the output of our Midi Output log instead.
I just tested the snapshot change with two banks and it worked better than ever.
It is 0 based now btw.
And remember that there might be the Roland setting enabled which yields to a previous-bank/program command if you send a 0. I changed to custom, so that nothing is done in that direction.
But changing it to kit v2 should solve it. I’m always in shock with the new builds as well, when the encoders don’t work
And Micki, if your IP is something like 192.168, you don’t have to obfuscate it. This means, that it’s your local net and doesn’t show us anything like where you live.
Hi my friends,
now I´m using the aruk-image and it receives PCh-Comands, wonderful.
Now I can integrate zynthian in my setup, without stomach pain. With one knob the whole equipment has the right sounds. Thanks
