Hi all !
I could finally build my Zynthian with the new ribbon cable Jofemodo kindly sent my to replace a faulty one. Thanks again !
I tried to update the software via command line from a freshly burnt SD card (zynthian_gorgona_omega_rbpi3_kitv2-2018-04-03) but the update process can’t complete because of a SSL certificates problem.
Here’s what i tried so far :
sudo update-ca-certificates
and
dpkt-reconfigure ca-certifictes
but i didn’t work.
I then deactivated the SSL verification for git with:
git config --global http.sslverify false
This time the update process could go further than before but i still got errors when it tried to download python packages (oyaml, psutil and so on…).
I tried to install them “by hand” with pip3 install oyaml but i got
Cannot fetch index base URL https://pypi.python.org/simple/ Could not find any downloads that satisfy the requirement oyaml
Same for every other python packages…
When checking pip logs it mentioned an SSL certificate problem as well…
Could not fetch URL https://pypi.python.org/simple/psutil/: connection error: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)
Any ideas ?
