Cannot use hotspot without Ethernet connected
I can run the gui over VNC from the zynth hotspot on an Android tablet, as long as I have an Ethernet connection to the zynth.
One lousy sound sample for anyone that can see what I’m doing wrong . . .
:face_with_monocle:
Quite strange! It seems a “routing” problem:
  • Can you access your zynthian (ssh/webconf) when is in HotSpot mode and no ethernet connection?
  • Can you use your zynthian as an Internet Access Point when connecting the zynthian to internet with ethernet?
Kind Regards,
I’ll give it a try. I discovered this when I tried to vnc onto the zynth hot-spot in the pub (no network cable available) it worked at home but not without the network cable connected which I do with all the home zynths
Does the pub WiFi use a captive portal?
Edit: ignore, irrelevant as you’re trying to use hot spot.
I have issues as well. First I thought, it would be Ethernet and WIFI related.
But only WIFI doesn’t work either.
First it assigns the 192.168.50.1, but after a couple of seconds it falls back to the self assigned address.
The zynthian log doesn’t show anything. Does anybody know where to those errors are logged?
