Change encoder direction
Hello,
I replaced my encoders, and now I find them acting the opposite direction as compared to the original encoders.
Is there any way to change the behaviour via a configuration file or do I have to swap wires?
regards,
hal
It’s easy to change this without re-wiring. Simply re-configure the wiring layout from:
http://zynthian.local/hw-wiring
You should swap the A & B encoder pins. If you have configured an official kit, then you should change to “custom kit” before.
Hi, thank you for the hint, that was really easy :slight_smile:
regards.
