Connecting capacitive buttons to mcp23017
Soldering right now. Meanwhile I have the idea that the above mentioned segfault error might be not related to this open heart surgery:
Jan 17 14:02:18 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.zynswitch_long: Looooooooong Switch 4
Jan 17 14:02:18 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'POWER_OFF' => None
Jan 17 14:02:19 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Jan 17 14:02:19 hannes-zynthian startx[2379]: INFO:zynthian_gui_confirm.switch_select: callback None
Jan 17 14:02:19 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.prune_screen_history: SCREEN HISTORY => ['mixer']
Jan 17 14:02:19 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'confirm' FROM SCREEN HISTORY => ['mixer']
Jan 17 14:02:19 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'confirm' => Back to 'root'
Jan 17 14:02:19 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.prune_screen_history: SCREEN HISTORY => []
Jan 17 14:02:19 hannes-zynthian startx[2379]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'mixer' FROM SCREEN HISTORY => []
Jan 17 14:02:19 hannes-zynthian startx[2379]: INFO:zynthian_gui_admin.power_off_confirmed: POWER OFF
Jan 17 14:02:19 hannes-zynthian startx[2379]: INFO:zynthian_state_manager.save_snapshot: Saving snapshot /zynthian/zynthian-my-data/snapshots/last_state.zss ...
Jan 17 14:02:19 hannes-zynthian startx[2379]: INFO:zynthian_gui.exit: STOPPING ZYNTHIAN-UI...
Jan 17 14:02:19 hannes-zynthian startx[2379]: INFO:zynthian_gui.osc_end: ZYNTHIAN-UI OSC server stopped
Jan 17 14:02:20 hannes-zynthian startx[2379]: ERROR:zynthian_chain_manager.remove_processor: Chain None doesn't exist!
Jan 17 14:02:20 hannes-zynthian startx[2379]: INFO:zynthian_gui.stop: All threads finished normally
Jan 17 14:02:20 hannes-zynthian startx[2379]: INFO:zynthian_main.<module>: Exit with code 0 ...
Jan 17 14:02:21 hannes-zynthian startx[2379]: zynmixer ended
Jan 17 14:02:21 hannes-zynthian startx[2379]: libzynaudioplayer exiting...
Jan 17 14:02:21 hannes-zynthian startx[2214]: ./zynthian.sh: line 316: 2379 Segmentation fault ./zynthian_main.py
Jan 17 14:02:21 hannes-zynthian startx[2214]: *******************
Jan 17 14:02:21 hannes-zynthian startx[2214]: EXIT STATUS => 139
Jan 17 14:02:21 hannes-zynthian startx[2563]: /zynthian/config/img/fb_zynthian_message.jpg is a 1280x800 JPEG image, color space YCbCr, 3 comps, Huffman coding.
Jan 17 14:02:21 hannes-zynthian startx[2563]: Zooming image by 100%...done
Jan 17 14:02:21 hannes-zynthian startx[2563]: Merging...done
Jan 17 14:02:21 hannes-zynthian startx[2563]: Building XImage...done
Jan 17 14:02:31 hannes-zynthian startx[2567]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Jan 17 14:02:31 hannes-zynthian startx[2567]: INFO:zynthian_gui_config.<module>: Kit Version: Custom
Jan 17 14:02:31 hannes-zynthian startx[2567]: INFO:zynthian_gui_config.<module>: Wiring Layout: MCP23017_ENCODERS_V5TOUCH
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin.call: STREAM b'IHDR' 16 13
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin.call: STREAM b'bKGD' 41 6
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin._open: b'bKGD' 41 6 (unknown)
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin.call: STREAM b'pHYs' 59 9
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin.call: STREAM b'tIME' 80 7
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin._open: b'tIME' 80 7 (unknown)
Jan 17 14:02:31 hannes-zynthian startx[2567]: DEBUG:PngImagePlugin.call: STREAM b'IDAT' 99 8192
Jan 17 14:02:31 hannes-zynthian startx[2567]: ZynCore: Configured 28 x Logical Zynswitches...
Jan 17 14:02:31 hannes-zynthian startx[2567]: ZynCore: Setting-up 4 x Physical Zynswitches...
Jan 17 14:02:31 hannes-zynthian startx[2567]: ZynCore: Setting-up 4 x Zynpots (zyncoders)...
Jan 17 14:02:31 hannes-zynthian startx[2567]: ZynCore->gpiod_start_callbacks: Callback thread created successfully
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_gui_config.config_zynpot2switch: zynpot2switch => [24, 25, 26, 27]
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1768515326.3700478
Jan 17 14:02:32 hannes-zynthian startx[2567]: Loaded libzynaudioplayer using libsndfile-1.2.0
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_main.<module>: STARTING ZYNTHIAN-UI ...
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_state_manager.__init__: Creating state manager
Jan 17 14:02:32 hannes-zynthian startx[2567]: Started zynmixer_chan
Jan 17 14:02:32 hannes-zynthian startx[2567]: Started zynmixer_bus
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_chain_manager.__init__: Creating chain manager
Jan 17 14:02:32 hannes-zynthian startx[2567]: Started libzynseq
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'MX' with ID '-2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_engine_alsa_mixer.get_controllers_dict: MIXER CTRL LIST: ['Digital_0', 'PGA_Gain_Left', 'Digital_1', 'PGA_Gain_Right', 'ADC_Left_Input', 'ADC_Right_Input']
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'TP' with ID '-4'
Jan 17 14:02:32 hannes-zynthian startx[2567]: Started libzynsmf
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_state_manager.start: Opened temperature sensor '/sys/class/hwmon/hwmon0/temp1_input'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_state_manager.start: Opened undervoltage sensor '/sys/class/hwmon/hwmon3/in0_lcrit_alarm'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 0 => midi_chan=None, zmop_index=None
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_apc_key25_mk2_sooperlooper'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_apc_key25'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_apc_key25_sooperlooper'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchkey_mini_mk3'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchpad_x'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_mackiecontrol'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_behringer_motor'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_riband'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchkey_mk4_37'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_midimix'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_mpk_mini_mk3_moder'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_apc_40_mk2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchpad_pro_mk3'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchkey_mini_mk4_37'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_fostex_mixtab'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_duopiano'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchpad_pro_mk2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_mpk_mini_mk3'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_worlde_mini_moder'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchpad_mini_mk3'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_korg_nanokontrol2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_launchpad_mini'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_ctrldev_manager.update_available_drivers: Loaded ctrldev driver class 'zynthian_ctrldev_akai_apc_key25_mk2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2_sooperlooper' for devices with ID 'APC Key 25 mk2 MIDI 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2_sooperlooper' for devices with ID 'APC Key 25 mk2 IN 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25' for devices with ID 'APC Key 25 MIDI 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25' for devices with ID 'APC Key 25 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25_sooperlooper' for devices with ID 'APC Key 25 MIDI 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25_sooperlooper' for devices with ID 'APC Key 25 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchkey_mini_mk3' for devices with ID 'Launchkey Mini MK3 IN 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchpad_x' for devices with ID 'Launchpad X IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_mackiecontrol' for devices with ID '*'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_behringer_motor' for devices with ID 'MOTÖR61 Keyboard IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_behringer_motor' for devices with ID 'MOTÖR49 Keyboard IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_riband' for devices with ID 'riband Bluetooth'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchkey_mk4_37' for devices with ID 'Launchkey MK4 37 DAW In'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchkey_mk4_37' for devices with ID 'Launchkey MK4 37 IN 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_midimix' for devices with ID 'MIDI Mix IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_mpk_mini_mk3_moder' for devices with ID 'MPK mini 3 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_40_mk2' for devices with ID 'APC40 mkII IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk3' for devices with ID 'Launchpad Pro MK3 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchkey_mini_mk4_37' for devices with ID 'Launchkey Mini MK4 37 IN 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_fostex_mixtab' for devices with ID '*'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_duopiano' for devices with ID 'GENERAL IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk2' for devices with ID 'Launchpad Pro IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_mpk_mini_mk3' for devices with ID 'MPK mini 3 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_worlde_mini_moder' for devices with ID 'WORLDE MINI IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchpad_mini_mk3' for devices with ID 'Launchpad Mini MK3 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_korg_nanokontrol2' for devices with ID 'nanoKONTROL2 IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_launchpad_mini' for devices with ID 'Launchpad Mini IN 1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 MIDI 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_ctrldev_manager.update_available_drivers: Found ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 IN 2'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_autoconnect.init: Initializing 27 slots for MIDI input devices
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_autoconnect.init: Initializing 24 slots for MIDI output devices
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'MR' with ID '-1'
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 0: system:midi_capture_1
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 1: ttymidi:MIDI_in
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 0: system:midi_playback_1
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 1: ttymidi:MIDI_out
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 2: ZynMaster:midi_in
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 3: ZynMidiRouter:seq_in
Jan 17 14:02:32 hannes-zynthian startx[2567]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 1, delay: 18.0us
Jan 17 14:02:32 hannes-zynthian startx[2567]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 2, delay: 8.0us
Jan 17 14:02:32 hannes-zynthian startx[2567]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! =>count: 3, delay: 18.0us
Jan 17 14:02:32 hannes-zynthian startx[2567]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'AP' with ID '-3'
Jan 17 14:02:32 hannes-zynthian startx[2567]: INFO:zynthian_state_manager.set_power_save_mode: Power Save Mode: OFF
Jan 17 14:02:33 hannes-zynthian startx[2567]: DEBUG:selector_events.__init__: Using selector: EpollSelector
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:multitouch._run: Starting multitouch on 'Waveshare Waveshare '
Jan 17 14:02:33 hannes-zynthian startx[2567]: DEBUG:zynthian_gui_brightness_config.get_backlight_sysctrl_fpath: Can't find a display brightness control file
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:zynthian_gui_brightness_config.init_ctrls: Setting LED brightness to 1.0.
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:zynthian_gui.zynswitches_init: INIT 28 ZYNSWITCHES ...
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:zynthian_gui.wiring_midi_setup: CUSTOM I/O SETUP...
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Jan 17 14:02:33 hannes-zynthian startx[2567]: DEBUG:zynthian_gui.prune_screen_history: SCREEN HISTORY => []
Jan 17 14:02:33 hannes-zynthian startx[2567]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'loading' FROM SCREEN HISTORY => []
Jan 17 14:02:33 hannes-zynthian startx[2567]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'loading' => Back to 'root'
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:zynthian_state_manager.load_snapshot: Loading snapshot '/zynthian/zynthian-my-data/snapshots/last_state.zss' ...
Jan 17 14:02:33 hannes-zynthian startx[2567]: INFO:zynthian_processor.get_bank_list: Loaded 0 banks
Jan 17 14:02:33 hannes-zynthian startx[2567]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'mixer' FROM SCREEN HISTORY => []
Jan 17 14:02:34 hannes-zynthian startx[2567]: DEBUG:zynthian_state_manager.update_thread: ************ CHECKING FOR UPDATES ... ************
