Advance that not knowing the English language but only Italian, I use a translator.
Thank you very much! I need to know why my pc window 10 does not connect lan with zynthian MOD
Hi @carlochipart!
Welcome on board!
Could you give some more info about your setup? Have you started the MOD-UI engine from the Zynthian GUI?
Some windows doesn’t have enabled the “link local” feature and doesn’t resolve the “zynthian.local” name. I’ve no idea of how to enable the link local in windows, sorry.
Anyway, you can use the IP. You can get it with the “network info” option from the admin menu.
FYI, all this info is explained in the wiki:
Kind Regards!
Hello Jofemodo! Thanks for your prompt reply.
Anyway I solved the problem myself, windows does not recognize “zynthian.local:8888”.
I solved it by putting IP Zinthian “192.168.1.211:888”.
Regards Carlo
Thank you anyway
Regards Carlo Bini
----- Messaggio originale -----
