Error installing ‘Conners_IR_library’ => Command ‘$ZYNTHIAN_RECIPE_DIR/install_Conners_IR_library.sh’ returned non-zero exit status 2.
Context:
SOFTWARE
zyncoder: vangelis (a03a079)
zynthian-ui: vangelis (4a30cb4)
zynthian-sys: vangelis (7a9ac68)
zynthian-data: vangelis (1fffd91)
zynthian-webconf: vangelis (af16c55)
Ups! You are right,
It’s fixed now. Simply update and try again.
Is it also possible to uninstall them?
by hand. no uninstall script
I don’t know if it’s related but I was trying to install this and I’m looking at the “loading circle” for more than 3 hours now, I guess it’s not happening. No error message.
/zynthian/zynthian-my-data/files/IRs/ is empty.
V5.1 hardware, ubuntu 24.04.4, firefox, fresh vangelis etched on sd just yesterday (with all updates since).
zyncoder: vangelis (a4b603f)
zynthian-ui: vangelis (9ada2fa)
zynthian-sys: vangelis (17ea3a9)
zynthian-data: vangelis (3f50b18)
zynthian-webconf: vangelis (b1cd979)
EDIT:
/zynthian/zynthian-sys/scripts/recipes/install_Conners_IR_library.sh
doesn’t seem to exist on my device
Do you have good connectivity? Are you using WIFI or ehternet?
This doesn’t exist any more.
Thanks for the quick answer. My Zynthian is hooked up via gigabit LAN and the connection is very reliable. Usually ~700MB would take less than 10 seconds.
Hi @OutOfCheese !
Please, access the package list in webconf, the try refreshing the package cache with CTRL+F5 and installing again. It should work now.
Enjoy,
Good morning,
yes it’s working now, package installed without problems. Thanks a lot!
