Hi All,
I’m converting my V3 Zynthian to dual mono inputs, instead of a single stereo input and noticed that the wiring is possibly wrong.
I found this topic about HB changing the specification of HifiBerry DAC+ADC (not the Pro, the standard version) from balanced input to unbalanced input: New Official Kit V2+: Audio Input is here! - #23 by riban
Then I checked the datasheet of the product here: https://www.hifiberry.com/docs/data-sheets/datasheet-dac-adc
And to my understanding one should be using pins 1, 3 and 5 of P6 connector (respectively right+, GND, left+) to connect stereo in - and a I’m planning to have them separated by drilling a new hole in the case to install the additional jack.
Can anyone confirm that above is the correct connection, please?
Thanks in advance,
~ACO
PS: And, for instance, it seems that the original wiring is neither stereo nor balanced mono, it is simply the right channel connected.
