Sorry, if asked before, only find for v2 module.
Are this the correct connectors need to use the Zynaptik Module and ZynScreen v1.5?
Thank you
Daniel
It’s described as a Raster Signal wire-board 1.00mm 4 pin (1x4) female, Molex 5013340100.
Any idea?
Nearly any connector on a 0.1" pitch will connect. I’ve not bought seperate connectors perhaps @jofemodo could comment?
The connectors used by zynaptic and zynscreen are JST SH 1mm.
