Custom controller pages (lv2 ttl) thread
I recently started editing some ttl from lv2 plugins, getting started with RipplerX and regrader.
Now I tried to get into Odin2, which was a little harder because of the 259 parameters. I also did not finish the parameter order inside a group and left this to default by now. But it’s far more usable in the current state already. It is not quite perfect, but a good starting point. I also attached a file for TAL Reverb 3.
lv2-custom.zip (7.4 KB)
The thing is, I don’t really know Odin 2 so well and had some hard time figuring out what the parameters really do, which were:
  • all these reset parameters
  • the “FilterN OscN Input” parameters
  • the OSC Step* parameters
Some parameters might not be usable so well, because they refer to e.g. filter types which aren’t switchable from the UI. Maybe we can have a general discussion how to deal with these parameters which are less usable from the native UI. In fact it seems that some basic concepts like choosing waveform, osc type or filter type are not exposed as a plugin parameter.
Maybe you might want to have a look into it. (You’d have to put the folders inside /zynthian/zynthian-data/custom-lv2 and update, but backup the original file in /usr/local/lib/lv2 and keep in mind you have to delete them manually in case it will be included in the repository) Maybe someone knowing the synth better than me might want to suggest some better ordering for some categories.
Also about the discussion: A gew weeks ago I looked into the file of our beloved SurgeXT and ran into some problems:
  • Here we have some over 700 parameters
  • On preset load they are not updated, so the UI doesn’t reflect the state
  • We have a bunch of parameters which we might never want to edit from the native UI (8 LFOs or more?)
  • There are a bunch of parameters which are used for different purposes depending on the configuration. E.g. the oscillators parameters labels (as far as I remember) refer to the analog osc choice and have completely other purposes if another osc type is selected, but the parameter labels will not be updated.
So how do we deal with that? Do we try to erase parameters which we might not use? Do we have to have a set of parameters for 8 LFOs, a double set for both “Scenes” and so on?
I’d say we could reduce the set to Scene A, 2 LFOs and lift the controls for filter A to the top of the controls to be more accessible. This might be lead to a more usable native UI interface. LFO 8 and the likes would be for the ones who prefer to leave the VNC on.
Surge uses a brilliant technique of assigning modulation to each parameter which uses the same knob for both the parameter value and the modulation amount from each modulator source. Basically, any parameter may be modulated by any modulator. (Check out their naitive UI. It is an excellent design principle.) This is a fantastic way to allow extreme flexibility within a UI. This does not scale well to external controls like hardware controllers or zynthian. I have avoided too much consideration of how we could fully control Surge. It is a daunting task that may require substantial change to zynthian which seems excessive for just one synth, even if that synth is excellent! (I think they did something similar with Helm.)
Yes, the native plugin is brilliant. I didn’t expect the whole modulation thing being accessible on zynthian. I actually at least wanted to order the parameters in some meaningful way and thought how to get at least access to some VIP parameters (macro/filter/adsr).
Hi, I did some custom lv2 ttl here:
custom-lv2.zip (9.6 KB)
TAL-Dub and TAL-Reverb-III are somehow finished, Odin2 is a good basis for finishing it.
I also wrote down some steps I do every time with these.
HowTo.md (1.0 KB)
That said, I have some questions, if somebody knows how to do it:
  • I wonder if I can add units without messing with the plugin
  • I also wonder if I can rescale the normalized floating values. For example the delay time in tal dub could be just scaled linear from 0.f .. 1.f to 0ms to 4000 ms. But I guess I can’t just rewrite the ttl.
  • I search to disable parameters from being displayed. For example every TAL plugin seems to have a “unused” parameter and some other quirky params (“Port 14”; “Live Mode”) which seem to do nothing. Also the lowpass resonance in Tal-Dub seems to be non functional as it is not represented in the native plugin UI.
  • So, questions are what I can mess with in the ttl files.
Well done @hannesmenzel!
Look at LV2 Port Properties for info about port parameters.
To request zynthian hide a port, addnotOnGUI.
To order the parameters, use displayPriorit.
I can’t remember if it is possible to scale the normalised values. {@jofemodo will remember.) There is a trick of using scale points to add discrete values in the range, but it is not very efficient for large quantity of values.
We don’t add units to values. It occupies valuable space in the display of the value. If advantageous, the units could be added to the control label.
I’m afraid scale points lead to a stepped parameter, which is fine for integer enum like controls like I did.
So you mean, at least port properties should be non destructive. Otherwise changing min, max, def values would probably break the plugin. The question is if the min, max and def values of the control ports are only used for display or if they are handed to the plugin parameter.
I understand that. Anyway, a delay time parameter going from 0.000 to 1.000 can be misinterpreted as seconds, where in this case the unit is “quarter seconds”.
This is fantastic, @hannesmenzel !
I just tested your custom TTLs and they work perfectly OK! It’s commited to Vangelis branch:
BTW, i hided some “unused” parameters by using the notOnGUI property.
Next time, feel free to create a PR in zynthian-data repository (Vangelis branch). PRs simplify testing and improves traceability.
This should be in the wiki. Do you have an editor account? If not, i will create one for you.
All the best,
As @riban says, adding the unit to the parameter name is the simplest solution we have currently.
Perhaps we could do this automatically when a unit is specified in the TTLs.
I do not and would appreciate to have one!
Great! The Odin ttl wasn’t really ready. But that is maybe a chance for learning pull requests later.
I commited to Vangelis (testing) branch :wink:
This is the idea :wink:
I just wrote some instructions for editing customized lv2 ttl files. Look here. Also feel free to edit futher.
I feel like we should sooner or later split the “Contributing to Zynthian Development” wiki page into smaller chunks and add a landing page referring to the sub pages.
Less soup for you tonight!!
One question: There are lv2 plugins that treat meter readouts as lv2 parameters like this (ZamComp here):
        a lv2:OutputPort, lv2:ControlPort ;
        lv2:index 14 ;
        lv2:name "Gain Reduction" ;
        lv2:symbol "gr" ;
        lv2:minimum 0 ;
        lv2:maximum 20 ;
        unit:unit unit:db ;
        lv2:index 15 ;
        lv2:name "Output Level" ;
        lv2:symbol "outlevel" ;
        lv2:minimum -45 ;
        lv2:maximum 20 ;
        unit:unit unit:db ;
Do we want to do something with this? They are currently not displayed when a lv2:OutputPort.
I don’t understand where is the issue. with this. Please, elaborate.
No issue, i wonder if we could use this for specific UI interaction. It seems in this case that this compressors gain reduction is exposed as a parameter, which could be used for a zynthian UI gain reduction meter.
These port values are reported in the monitoring dictionary which a gui widget may use.
By the way, I did some ttls recently.
I just wanted to ask if we could have a user ttl folder in zynthian-my-data similar to this:
It would make working on custom ttl’s a lot easier.
