Hello, welcome.
Probably a good idea to show us what you are using. Could you provide a picture of what you describe as Zynthian…?
That way we get an idea of the context.
Also if you could grab a screen shot of the webconf home page?
hi,
thanks Wyleu.
In fact, i use a raspiaudio card. i install the driver with the command line i terminal :
wget -O - script.raspiaudio.com | bash
and the card is install. an “play -l” give my the card name etc. then i’m going to the audio setup, choosing custom and modify the line with :
-P 70 -t 2000 -s -d alsa -d hw:Sndrpihifiberry -r 44100 -p 256 -n 2 -X raw
i save, i reebot and ALL is ok.
i can play with Zynthian synth during x hours. When i power it off … it is DEAS : )
i’m obliged to setup audio with Rasp audio, saving, reboot, re install audio driver to play again.
tha is … the first step - that is quit stable - because when all is ok, and when i just want to add the encoder number value … DEAD AGAIN !!!
i’ve past about 10, 20, 30 hours to try to understand how Zynthian works but it is not “acquis” for me.
You’re experiencing the damn screen “ERROR” with IP … again
… So welcome to the club. Exotic hardware means sometimes hassels
In Webconf,
be sure you have choose “Custom” Kit
Choose Hifiberry Dac Light as audio sound card in the Webconf audio settings
And of course, configure other hardware like display and encoders
If this doesn’t work after reboot, more informations will be needed to investigate further.
In that case can you please copy paste here the output of the following commands (you can do that within the Webconf through its Terminal emulation page)
dmesg (this will provide all Linux kernel harware related messages)
aplay -l (this will list all audio out devices)
systemctrl status jackd (jackd is as a service needed by Zynthian to get up.)
I’ve just do what you write and all work fine Directly !!! Incredible
i don’t understand cos i’ve try it but may be with the driver load before.
i was in the wrong way and thinks to all for you answers cos i was really ready to stop trying.
Zynthian is really amazing. i’ve try it with my guitare Synth and it is fun.
I’ve also surely buy the wrong audio card because there is no input.
