Obviously this is a bad design that needs to be changed, nevertheless I thought its useful to report: If there is an attempt to do fputs(stdout, ....) on the audio thread, this might result in a deadlock, the only escape is to remove the instrument.
EDIT: It doesn’t seem to matter which thread is logging, any thread that logs might hit a deadlock sooner or later.
(gdb) bt
#0 __GI___libc_write (nbytes=51, buf=0x55562b4b8c60, fd=1) at ../sysdeps/unix/sysv/linux/write.c:26
#1 __GI___libc_write (fd=1, buf=buf@entry=0x55562b4b8c60, nbytes=nbytes@entry=51) at ../sysdeps/unix/sysv/linux/write.c:24
#2 0x00007fff45b967fc in _IO_new_file_write (f=0x7fff45cc15c0 <_IO_2_1_stdout_>, data=0x55562b4b8c60, n=51) at ./libio/fileops.c:1180
#3 0x00007fff45b95c0c in new_do_write
(fp=0x7fff45cc15c0 <_IO_2_1_stdout_>, data=0x55562b4b8c60 "append@141: Received sysex: f0002033011071405f23f7\n, MHz: 128.9325 (113.8459 avg)\n\ned preset\n, mf=000082, pd=00000c, df=000001 => cycles per sample=462, predefined samplerate=144000\n\n", to_do=to_do@entry=51)
at ./libio/libioP.h:947
#4 0x00007fff45b97840 in _IO_new_do_write (fp=<optimized out>, data=<optimized out>, to_do=51) at ./libio/fileops.c:425
#5 0x00007fff45b96e68 in _IO_new_file_xsputn (n=51, data=<optimized out>, f=0x7fff45cc15c0 <_IO_2_1_stdout_>) at ./libio/libioP.h:947
#6 _IO_new_file_xsputn (f=0x7fff45cc15c0 <_IO_2_1_stdout_>, data=<optimized out>, n=51) at ./libio/fileops.c:1196
#7 0x00007fff45b8b0d4 in __GI__IO_fputs (str=0x7ffeb011d5c0 "append@141: Received sysex: f0002033011071405f23f7\n", fp=0x7fff45cc15c0 <_IO_2_1_stdout_>) at ./libio/libioP.h:947
#8 0x00007fff40ebec8c in Logging::g_logToConsole(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#9 0x00007fff40e7d2c0 in virusLib::Hdi08TxParser::append(unsigned int) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#10 0x00007fff40e73bb8 in virusLib::Microcontroller::processHdi08Tx(std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> >&) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#11 0x00007fff40e740d4 in virusLib::Microcontroller::readMidiOut(std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> >&) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#12 0x00007fff40e554bc in virusLib::Device::process(std::array<float const*, 4ul> const&, std::array<float*, 12ul> const&, unsigned long, std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> > const&, std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> >&) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#13 0x00007fff40e89514 in synthLib::ResamplerInOut::process(std::array<float const*, 4ul> const&, std::array<float*, 12ul>&, std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> > const&, std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> >&, unsigned int, std::function<void (std::array<float const*, 4ul> const&, std::array<float*, 12ul> const&, unsigned long, std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> > const&, std::vector<synthLib::SMidiEvent, std::allocator<synthLib::SMidiEvent> >&)> const&) ()
#14 0x00007fff40e86c40 in synthLib::Plugin::process(std::array<float const*, 4ul> const&, std::array<float*, 12ul> const&, unsigned long, float, float, bool) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#15 0x00007fff40de5694 in pluginLib::Processor::processBlock(juce::AudioBuffer<float>&, juce::MidiBuffer&) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#16 0x00007fff40d242d0 in juce::lv2_client::LV2PluginInstance::run(unsigned int) () at /usr/local/lib/lv2/OsTIrus.lv2/libOsTIrus.so
#17 0x000055560f39c51c in jalv_run ()
#18 0x000055560f398800 in jack_process_cb ()
#19 0x00007fff46a44138 in () at /lib/aarch64-linux-gnu/libjack.so.0
#20 0x00007fff46a43df8 in () at /lib/aarch64-linux-gnu/libjack.so.0
#21 0x00007fff46a62294 in () at /lib/aarch64-linux-gnu/libjack.so.0
#22 0x00007fff45b9ee30 in start_thread (arg=0x7fffd8ed9f07) at ./nptl/pthread_create.c:442
#23 0x00007fff45c07adc in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:79
