Default engine and patch on startup
Hi, is it possible to configure zynthian so that on startup, a specific engine and patch is loaded so that playing can start straight away without having to interact with the gui? For instance a grand piano patch in the linux sampler.
Hi @cdswift!
Yes, in the last version you can setup a default snapshot (default.zss) that is loaded in startup. This feature is only available in the “mod” branch, that can’t be installed in the current SD image. I hope to upload the new SD image in a few days and this feature will be available out the box :wink:
