You are correct but there are some values that could be configured, controls grouped & ordered and display names rationalised. I am not sure how we might handle the dynamic change of parameter range for predelay, delay and pitchshift but all the others could be configured. Note that the TTL says “Tab” where I think it should be “Tap” and if you leave spaces between words, the new control label algorithm will better handle the display of names. (It can also handle camleCase but explicitly defining words is better.)
[Edit] Whilst there you could add the presets.
