Audio-Effect: PitchedDelay: No Presets
Hi there,
I am just playing around with the Audio-Plugin “Pitched Delay” and saw, that the Zynthian UI isn’t giving the opportunity to access the presets.
I played with it a little on my computer, insted on the zynthian itself. Saved a preset and found where it was stored on my computer. I then wanted to transfer it to the Zynthian. On my Computer it was stored in my ~/.config/lkjb/PitchedDelayPresets.xml. Similarly it was store on Zynthian in /root/.config/lkjb/PitchedDelayPresets.xml.
But then in the Zynthian UI, I saw that there is no option to load any presets. Actually the presets are just added in the XML-file right one after the other, so all presets are saved in that file and I copied my new preset-file to that locaition on Zynthian.
Is it actually difficult to enable any in-Zynthian-UI preset dialog for that plugin?
Hi @Jojo_Action !
Zynthian UI need the rpesets to be in LV2 format, so you need to convert your XML presets. Follow these steps:
  • Enable VNC. You should see the XML presets in the plugin’s native gui accessed from VNC.
  • Save your presets in LV2 format from the topbar menu. You have to do it one by one.
  • From the zynthian UI, re-scan for new presets from the plugin 's preset options.
  • Now the new LV2 presets should be available from the UI.
