Is there a way to use Zynthian like an actual computer? Like with a keyboard and mouse? I got the kit with the knobs and touchscreen, but they either work poorly or not at all, so I’ve been using a wireless keyboard/touchpad to get around. I can navigate for the most part, but editing parameters is a pain and a half.
Stick a raspbian image in it… I do it all the time when I’m building stuff.
Can you tell us more ?
How would I do that? Just image both ZynthianOS and Rasbpian to the SD card?
The knobs/buttons don’t respond at all. I tried plugging each one into each of the ports, but nothing happens. The touchscreen I think got damaged as I installed it into the case, so it’ll act weird depending on where I touch it.
That’s what I’d been using, but I don’t know how to make it edit the parameters you’d normally use the knobs for.
klick on the link in my previous message
It says how to emulate pressing the buttons, but it doesn’t say anything about turning the knobs.
It has been implemented but the wiki wasn’t updated.
Go in webconf:Interface=>UI key bindings you’ll find the keybindings and will be able to modify them if you need to.
I’ve just done it !
