Did anybody get the Hifiberry dacplusadc card working on PI5 with oram?
The card is shown after typing aplay -l, but jack does not seem to recognise it.
Also with only bookworm flashed on de SD card it does not work.
Who has the solution?
Thanks a lot and enjoy your day,
Maarten
I’m using the dacplusadcpro, that is similar but not the same. At first, it was failing too, but suddenly, with a recent firmware update, it started to work. Perhaps you could try to force a rpi-update …
Thanks a lot Jofemodo. Unfortunately … no success yet… I will use USB audio for now. Thursday… 2 weeks holiday on an Greek Island…
After that starting from scratch with a new image.
Wonderful project this. Thanks again!
Maarten
Hi Guys,
I have the same problem with HifiBerry DAC+ on RPI5 + Oram.
Strangly enough it was working yestarday. Booted from SD card and even from NVME, I set up the Audio to DAC+, booted again and it worked, sound, everything. even performed update, worked after. Today I start it again and GUI keeps restartaing (quite fast, 1-2 seconds). So I have made a fresh SD card with ORAM. No luck, after settings the DAC+ GUI was restarting - showed ERROR. after Update, same story, except it does not show that ERROR message and restarts are much faster. I checked the DAC+ on RPI4 with stable release of ZynthOS, no problem there, so the card is ok.
Back to the PI5 no luck. When I change the Audio to “Dummy” it boots without problems. When I check aplay -l, I can se the DAC+ there together with HDMI’s and Dummies, alsamixer sees it as well, i2cdetect -y 1, shows the card on the correct location 0x4d (I think). When I change te Audio to DAC+, aplay -l no longer shows te card and GUI keeps restarting. Card is working, PI is working so what gives?
Does the name in aplay -l
match what is in the configuration line? Sometimes alsa renames devices.
I say alsa, I mean kernel updates.
