C0d3man
February 15, 2020, 4:44pm
1
Hi Zynthianiacs,
I have upgraded my first Zynthian towards a RPi4. It was a bit tricky to install it together with an aluminum radiator case - but it worked:
I used a 40-pin riser for installing the Hifiberry on top of the case. I also had to change the Micro-USB power adapter towards a USB-C one.
Some small problem occured with the actual firmware due to the small PiTFT display (2.8"). I will open another thread for this.
And of course some fast recorded music (theme from āRock is a drugā from the Spliff-Radio-Show):
https://discourse.zynthian.org/uploads/default/original/2X/7/76411f00b6ce0b2e42316cde0aa7ff89dadc050a.mp3
(MDA-EPiano with 3-Band EQ and YK-Chorus)
https://discourse.zynthian.org/uploads/default/original/2X/e/edb4622d98555aa7b52aef0d340b98109c709203.mp3
(Pianoteq EPiano MK-II Jazzy Steinberg D)
Regards, Holger
wyleu
February 15, 2020, 5:39pm
2
It started out as rather spaceman came travelling⦠But moved away very succesfully.
Course if you wanted to do the sequence bits from the Chris de Burgh classic I wouldnāt be surprised if was recognised by a few round hereā¦
mj_prod
February 15, 2020, 5:56pm
3
Hi @wyleu and @C0d3man ,
here is a youtube link , but better listen to from the start⦠you wonāt regret this inspirational piece of german music history!
Sure? It sounds like a grand piano on my phoneā¦
C0d3man
February 16, 2020, 8:26am
6
Uploaded the wrong file⦠this one was the Steinberg D (or perhaps the ring tone of my Pixel-3?)
Regards, Holger
