Enabled engines copy
I would like to have same enabled engines in two Zynthians.
How can I get that result without doing it manually?
In theory it should be possible to
  1. Enable engines on the first zynthian
  2. Copy over /zynthian/config/engine_config.json to the second one.
Of course the same engines should be installed on these, so I’d only do this if you’re sure both are on the same update level and had no failed updates in the past.
