Enabled engines not available [SOLVED]
On the zynthian configuration the default has many engines and midi tools enabled but they are not available to select on the Zynthian device interface on Add Instrument chain or add Midi-FX. I wanted to ad the AOELUS but it’s not on the list of Synths, also when I tried to add Midi-FX )following the tutorial) the only one available is Appregiator, even though many more are enabled on the configuration
Aeolus should be in the Organ section, depending on your current OS version you need to switch categories (most likely encoder 3)
Thanks, I didn’t even know that categories existed.
Hi @Ernisius , are you using Oram? Wondering since this is an area where the usability has improved in Vangelis.
Yes, I am using ORAM. That is the latest stable image, so is Vangelis like a beta image?. but my issue was when adding a chain I totally missed that categories were selectable. Now I have lots more to play with. but I will try out vangelis.
Hi @Ernisius
While ORAM is current stable version, the Vangelis successor is getting all the attention lately.
I recommend taking a new SD card to play with it, the announcement is here: Vangelis 2606 BETA Image is released. You SHOULD download & install! - Software Updates - Zynthian Discourse
