Enabling and disabling effects via push button
I intend to use the Zynthian purely as an FX pedal for a particular experimental setup. Is there a way to switch effects on and off using the push buttons on the V4 kit, so that I can bypass the chain of effects when I don’t want them to modify the incoming sound.
This is similar to the discussion we are having about Sooperlooper. Many effects have a bypass parameter that can be masked to a CC. A recent enhancement allows CC to act as a toggle which can help to make Zynthian work more like a stomp box.
ZynDistortion does not appear to have a bypass perimeter, unfortunately.
I have a related question.
Is it possible to map the S1 - S4 buttons to toggle controls?
I’ve tried doing this via MIDI learn, but to no avail.
Most effects in mod-ui have bypass parameter, but outside of mod-ui I haven’t found any that have it.
MOD-UI add a bypass toggle to all FXs.
Zynthian currently doesn’t, so we relay in the plugin implementing such a toggle, but many doesn’t have such a toggle. This should be improved in zynthian.
At least I have managed to map the switches to some of the contrals. Only heads to switch the wiring to V4 CC Switches.
I’m trying to access mod-ui via http://zynthian.local:8888, but I’m getting a connection error, as if the service were not running.
I checked the mod-ui user guide, but couldn’t find any information about this particular issue.
Must it be enabled somewhere?
Have you added a chain with mod-ui?
Nope. Thanks for the heads-up!
Zynthian truly is the gift that keeps on giving.
I actually thought about buying a Mod Dwarf.
No longer needed, it seems.
Hi
Is the toggle for all effects always in the list to do ?
We have a dev branch that implements per-processor bypass. We don’t currently have a feature request to bypass all effects processors with a single control.
Oh i did not write clear, i meant per-processor bypass.
