Hi… with Gorgona Next, i tried to reload beta plugins for mod. It worked fine until i decided to run beta update_system.sh.
After that, system boots very slowly,
if trying to load a plugin, the zynthian error splash screen (or black screen with a cursor) appears after a while…and returns to snapshot page.
Running zynthian from terminal this is the result
Zyncoder: Zynswitches poll thread created successfully
Zyncoder: MIDI tuning frequency set to 440 Hz (8192)
INFO:root:SWITCHES INIT...
INFO:root:SETUP GPIO SWITCH 0 => 107
INFO:root:SETUP GPIO SWITCH 1 => 23
INFO:root:SETUP GPIO SWITCH 2 => 106
INFO:root:SETUP GPIO SWITCH 3 => 2
DEBUG:root:ZCTRL 'Layer': 0 (0 -> 2), None, None
DEBUG:root:Snapshot Bank '00001' => MIDI bank 0.
DEBUG:root:Snapshot Bank '00002-STANDARD' => MIDI bank 1.
DEBUG:root:Snapshot Bank '00003-MD-SNAPSHOTS' => MIDI bank 2.
DEBUG:root:ZCTRL 'Bank': 0 (0 -> 3), None, None
ERROR:zynautoconnect.zynthian_autoconnect:ERROR Autoconnecting: list index out of range
to be precise, i can’t hear no sound anymore, but it’s not a soundcard issue, but the usb-midi.
Noticed this when i loaded mod-ui. Only serial port is present… even if i unplug-plug usb bidi keyboard, nothing appears…
[update] now serial midi disappeared too.
Can i hope in solving reinstalling something, or reformat sd card and reload fresh image
