Had my Zynthian since last year and loving it. No issues with software until now
Recently updated to the latest software revision. After updating, zynthian gives me an error loop and the logs loop over and over with some file loading errors. Maybe I need to do something which I have not tried yet to fix it.
Any help is appreciated. This is a V3 Kit
– Logs begin at Thu 2019-02-14 10:11:58 GMT. –
Mar 25 13:14:51 zynthian startx[482]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Mar 25 13:14:51 zynthian startx[482]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Mar 25 13:14:51 zynthian startx[482]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl' Mar 25 13:14:51 zynthian startx[482]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl Mar 25 13:14:53 zynthian startx[482]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory) Mar 25 13:14:53 zynthian startx[482]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl’
Mar 25 13:14:53 zynthian startx[482]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl
Mar 25 13:14:53 zynthian startx[482]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory)
Mar 25 13:14:53 zynthian startx[482]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl' Mar 25 13:14:53 zynthian startx[482]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl Mar 25 13:14:54 zynthian startx[482]: Traceback (most recent call last): Mar 25 13:14:54 zynthian startx[482]: File "./zynthian_gui.py", line 84, in <module> Mar 25 13:14:54 zynthian startx[482]: from zyngui.zynthian_gui_touchscreen_calibration import zynthian_gui_touchscreen_calibration Mar 25 13:14:54 zynthian startx[482]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_touchscreen_calibration.py", line 32, in <module> Mar 25 13:14:54 zynthian startx[482]: from evdev import InputDevice, ecodes Mar 25 13:14:54 zynthian startx[482]: ModuleNotFoundError: No module named 'evdev' Mar 25 13:14:55 zynthian startx[482]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma Mar 25 13:14:55 zynthian startx[482]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546 Mar 25 13:14:55 zynthian startx[482]: Zooming image by 100%...done Mar 25 13:14:55 zynthian startx[482]: Merging...done Mar 25 13:14:55 zynthian startx[482]: Building XImage...done Mar 25 13:15:00 zynthian startx[482]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/> Mar 25 13:15:00 zynthian startx[482]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/> Mar 25 13:15:00 zynthian startx[482]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory) Mar 25 13:15:00 zynthian startx[482]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl’
Mar 25 13:15:00 zynthian startx[482]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Mar 25 13:15:01 zynthian startx[482]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory)
Mar 25 13:15:01 zynthian startx[482]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl' Mar 25 13:15:01 zynthian startx[482]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl Mar 25 13:15:01 zynthian startx[482]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory) Mar 25 13:15:01 zynthian startx[482]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl’
Mar 25 13:15:01 zynthian startx[482]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl
Mar 25 13:15:02 zynthian startx[482]: Traceback (most recent call last):
Mar 25 13:15:02 zynthian startx[482]: File “./zynthian_gui.py”, line 84, in
Mar 25 13:15:02 zynthian startx[482]: from zyngui.zynthian_gui_touchscreen_calibration import zynthian_gui_touchscreen_calibration
Mar 25 13:15:02 zynthian startx[482]: File “/home/pi/zynthian-ui/zyngui/zynthian_gui_touchscreen_calibration.py”, line 32, in
Mar 25 13:15:02 zynthian startx[482]: from evdev import InputDevice, ecodes
Mar 25 13:15:02 zynthian startx[482]: ModuleNotFoundError: No module named ‘evdev’
Mar 25 13:15:03 zynthian startx[482]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Mar 25 13:15:03 zynthian startx[482]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Mar 25 13:15:03 zynthian startx[482]: Zooming image by 100%…done
Mar 25 13:15:03 zynthian startx[482]: Merging…done
Mar 25 13:15:03 zynthian startx[482]: Building XImage…done
At this point the logs continue to repeat the same information
Try using webconf to navigate to SOFTWARE->LV2-Plugins and click the “Search for new Plugins & Presets” buttons then wait for the page to complete its process (may be a couple of minutes).
Same behavior after searching for new plugins. Maybe I need to reimage? I have no snapshots or other backups prepared.
Mar 25 16:10:52 zynthian startx[484]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of http://gareus.org/oss/lv2/b_whirl#extended from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/>
Mar 25 16:10:52 zynthian startx[484]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Mar 25 16:10:52 zynthian startx[484]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory)
Mar 25 16:10:52 zynthian startx[484]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl' Mar 25 16:10:52 zynthian startx[484]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl Mar 25 16:10:53 zynthian startx[484]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory) Mar 25 16:10:53 zynthian startx[484]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl’
Mar 25 16:10:53 zynthian startx[484]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl
Mar 25 16:10:53 zynthian startx[484]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory)
Mar 25 16:10:53 zynthian startx[484]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl' Mar 25 16:10:53 zynthian startx[484]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl Mar 25 16:10:54 zynthian startx[484]: Traceback (most recent call last): Mar 25 16:10:54 zynthian startx[484]: File "./zynthian_gui.py", line 84, in <module> Mar 25 16:10:54 zynthian startx[484]: from zyngui.zynthian_gui_touchscreen_calibration import zynthian_gui_touchscreen_calibration Mar 25 16:10:54 zynthian startx[484]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_touchscreen_calibration.py", line 32, in <module> Mar 25 16:10:54 zynthian startx[484]: from evdev import InputDevice, ecodes Mar 25 16:10:54 zynthian startx[484]: ModuleNotFoundError: No module named 'evdev' Mar 25 16:10:55 zynthian startx[484]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma Mar 25 16:10:55 zynthian startx[484]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546 Mar 25 16:10:55 zynthian startx[484]: Zooming image by 100%...done Mar 25 16:10:55 zynthian startx[484]: Merging...done Mar 25 16:10:55 zynthian startx[484]: Building XImage...done Mar 25 16:11:00 zynthian startx[484]: lilv_world_load_bundle(): warning: Replacing version 2058.0 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl_xt/> Mar 25 16:11:00 zynthian startx[484]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/> Mar 25 16:11:00 zynthian startx[484]: error: failed to open file /zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl (No such file or directory) Mar 25 16:11:00 zynthian startx[484]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl’
Mar 25 16:11:00 zynthian startx[484]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2/ProM.lv2/manifest.ttl
Mar 25 16:11:02 zynthian startx[484]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl (Not a directory)
Mar 25 16:11:02 zynthian startx[484]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl' Mar 25 16:11:02 zynthian startx[484]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/manifest.ttl/manifest.ttl Mar 25 16:11:02 zynthian startx[484]: error: failed to open file /zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl (Not a directory) Mar 25 16:11:02 zynthian startx[484]: lilv_world_load_file(): error: Error loading file file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl’
Mar 25 16:11:02 zynthian startx[484]: lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-my-data/presets/lv2/Clavinet.ttl/manifest.ttl
Mar 25 16:11:03 zynthian startx[484]: Traceback (most recent call last):
Mar 25 16:11:03 zynthian startx[484]: File “./zynthian_gui.py”, line 84, in
Mar 25 16:11:03 zynthian startx[484]: from zyngui.zynthian_gui_touchscreen_calibration import zynthian_gui_touchscreen_calibration
Mar 25 16:11:03 zynthian startx[484]: File “/home/pi/zynthian-ui/zyngui/zynthian_gui_touchscreen_calibration.py”, line 32, in
Mar 25 16:11:03 zynthian startx[484]: from evdev import InputDevice, ecodes
Mar 25 16:11:03 zynthian startx[484]: ModuleNotFoundError: No module named ‘evdev’
Mar 25 16:11:03 zynthian startx[484]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Mar 25 16:11:03 zynthian startx[484]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Mar 25 16:11:03 zynthian startx[484]: Zooming image by 100%…done
Mar 25 16:11:03 zynthian startx[484]: Merging…done
Mar 25 16:11:03 zynthian startx[484]: Building XImage…done
My fresh system from latest image takes 3:30 to search for new plugins (on Pi 3), with no visible result. Does seem to crash the web interface, giving “500: Internal Server Error” on any further actions.
Also noted the MOD window RAM status on an mt pedal board ramps up from 34% to 62% during this 3:30.
I have captured the webconf issue here. Webconf is consuming memory and not releasing it on each scan so after a couple of scans it has eaten all the available memory and stops working. It may not be webconf’s fault as it calls another zynthian python function to do the work. I have marked this as being in the next sprint as it falls into the catagory of significant impact to stable release which is what this sprint is targetted at resolving.
It is complaining about LV2 preset files missing from my-data. Will you share your “SOFTWARE” versions from the webconf main dashboard: http://zynthian.local?
