Hi everybody,
I am a new zynthian user, as I recently build mine
I upgraded the zynthian, with the script.
After rebooting, I got the error splash screen.
Please find the logs at the end (stdout/stderr output for the command âservice synthian startâ, + bash in echo mode).
I also have a weid USB/midi input handling but I am going to make another thread for that if I canât find the issue (Endless midi notes + double octave catching).
Thank you very much for any help.
Claude
service zynthian start logs:
Nov 11 17:38:40 zynthian systemd[1]: Starting Zynthian User InterfaceâŠ
Nov 11 17:38:40 zynthian systemd[1]: Started Zynthian User Interface.
Nov 11 17:38:40 zynthian startx[10504]: X.Org X Server 1.18.4
Nov 11 17:38:40 zynthian startx[10504]: Release Date: 2016-07-19
Nov 11 17:38:40 zynthian startx[10504]: X Protocol Version 11, Revision 0
Nov 11 17:38:40 zynthian startx[10504]: Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Nov 11 17:38:40 zynthian startx[10504]: Current Operating System: Linux zynthian 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l
Nov 11 17:38:40 zynthian startx[10504]: Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.me
Nov 11 17:38:40 zynthian startx[10504]: Build Date: 11 November 2016 11:59:59AM
Nov 11 17:38:40 zynthian startx[10504]: xorg-server 2:1.18.4-2+rpi1 (Debian -- User Support)
Nov 11 17:38:40 zynthian startx[10504]: Current version of pixman: 0.33.3
Nov 11 17:38:40 zynthian startx[10504]: Before reporting problems, check http://wiki.x.org
Nov 11 17:38:40 zynthian startx[10504]: to make sure that you have the latest version.
Nov 11 17:38:40 zynthian startx[10504]: Markers: (â) probed, (**) from config file, (==) default setting,
Nov 11 17:38:40 zynthian startx[10504]: (++) from command line, (!!) notice, (II) informational,
Nov 11 17:38:40 zynthian startx[10504]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Nov 11 17:38:40 zynthian startx[10504]: (==) Log file: â/var/log/Xorg.0.logâ, Time: Sat Nov 11 17:38:40 2017
Nov 11 17:38:40 zynthian startx[10504]: (==) Using config directory: â/etc/X11/xorg.conf.dâ
Nov 11 17:38:40 zynthian startx[10504]: (==) Using system config directory â/usr/share/X11/xorg.conf.dâ
Nov 11 17:38:40 zynthian startx[10504]: + â[â -d /zynthian/config â]â
Nov 11 17:38:40 zynthian startx[10504]: + source /zynthian/config/zynthian_envars.sh
Nov 11 17:38:40 zynthian startx[10504]: ++ export âSOUNDCARD_NAME=HifiBerry DAC+â
Nov 11 17:38:40 zynthian startx[10504]: ++ SOUNDCARD_NAME=âHifiBerry DAC+â
Nov 11 17:38:40 zynthian startx[10504]: ++ export SOUNDCARD_CONFIG=dtoverlay=hifiberry-dacplus
Nov 11 17:38:40 zynthian startx[10504]: ++ SOUNDCARD_CONFIG=dtoverlay=hifiberry-dacplus
Nov 11 17:38:40 zynthian startx[10504]: ++ export âJACKD_OPTIONS=-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ
Nov 11 17:38:40 zynthian startx[10504]: ++ JACKD_OPTIONS=â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ
Nov 11 17:38:40 zynthian startx[10504]: ++ export âDISPLAY_NAME=PiScreen 3.5 (v2)â
Nov 11 17:38:40 zynthian startx[10504]: ++ DISPLAY_NAME=âPiScreen 3.5 (v2)â
Nov 11 17:38:40 zynthian startx[10504]: ++ export âDISPLAY_CONFIG=dtoverlay=piscreen2r-notouch,rotate=270\ndtoverlay=ads7846,speed=2000000,cs=1,penirq=17,penirq_pull=2,swapxy=1,xoh
Nov 11 17:38:40 zynthian startx[10504]: ++ DISPLAY_CONFIG=âdtoverlay=piscreen2r-notouch,rotate=270\ndtoverlay=ads7846,speed=2000000,cs=1,penirq=17,penirq_pull=2,swapxy=1,xohms=100,
Nov 11 17:38:40 zynthian startx[10504]: ++ export DISPLAY_WIDTH=480
Nov 11 17:38:40 zynthian startx[10504]: ++ DISPLAY_WIDTH=480
Nov 11 17:38:40 zynthian startx[10504]: ++ export DISPLAY_HEIGHT=320
Nov 11 17:38:40 zynthian startx[10504]: ++ DISPLAY_HEIGHT=320
Nov 11 17:38:40 zynthian startx[10504]: ++ export FRAMEBUFFER=/dev/fb1
Nov 11 17:38:40 zynthian startx[10504]: ++ FRAMEBUFFER=/dev/fb1
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_AUBIONOTES=1
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_AUBIONOTES=1
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_TOUCHOSC=1
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_TOUCHOSC=1
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_WIRING_LAYOUT=MCP23017_ENCODERS
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_WIRING_LAYOUT=MCP23017_ENCODERS
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_WIRING_ENCODER_A=102,105,110,113
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_WIRING_ENCODER_A=102,105,110,113
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_WIRING_ENCODER_B=101,104,109,112
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_WIRING_ENCODER_B=101,104,109,112
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_WIRING_SWITCHES=100,103,108,111
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_WIRING_SWITCHES=100,103,108,111
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_COLOR_BG=#000000
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_COLOR_BG=â#000000â
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_COLOR_TX=#ffffff
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_COLOR_TX=â#ffffffâ
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_COLOR_ON=#ff0000
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_COLOR_ON=â#ff0000â
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_COLOR_PANEL_BG=#3a424d
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_COLOR_PANEL_BG=â#3a424dâ
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_FONT_FAMILY=Audiowide
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_FONT_FAMILY=Audiowide
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_FONT_SIZE=14
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_FONT_SIZE=14
Nov 11 17:38:40 zynthian startx[10504]: ++ export âZYNTHIAN_AUBIONOTES_OPTIONS=-O complex -t 0.5 -s -88 -p yinfft -l 0.5â
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_AUBIONOTES_OPTIONS=â-O complex -t 0.5 -s -88 -p yinfft -l 0.5â
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_ENABLE_CURSOR=0
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_ENABLE_CURSOR=0
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_DIR=/zynthian
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_DIR=/zynthian
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_SW_DIR=/zynthian/zynthian-sw
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_SW_DIR=/zynthian/zynthian-sw
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_UI_DIR=/zynthian/zynthian-ui
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_UI_DIR=/zynthian/zynthian-ui
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_SYS_DIR=/zynthian/zynthian-sys
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_SYS_DIR=/zynthian/zynthian-sys
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_DATA_DIR=/zynthian/zynthian-data
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_DATA_DIR=/zynthian/zynthian-data
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_MY_DATA_DIR=/zynthian/zynthian-my-data
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_MY_DATA_DIR=/zynthian/zynthian-my-data
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_RECIPE_DIR=/zynthian/zynthian-sys/scripts/recipes
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_RECIPE_DIR=/zynthian/zynthian-sys/scripts/recipes
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_PLUGINS_DIR=/zynthian/zynthian-plugins
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_PLUGINS_DIR=/zynthian/zynthian-plugins
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_MY_PLUGINS_DIR=/zynthian/zynthian-my-plugins
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_MY_PLUGINS_DIR=/zynthian/zynthian-my-plugins
Nov 11 17:38:40 zynthian startx[10504]: ++ export ZYNTHIAN_PLUGINS_SRC_DIR=/zynthian/zynthian-sw/plugins
Nov 11 17:38:40 zynthian startx[10504]: ++ ZYNTHIAN_PLUGINS_SRC_DIR=/zynthian/zynthian-sw/plugins
Nov 11 17:38:40 zynthian startx[10504]: ++ export LV2_PATH=/zynthian/zynthian-plugins/lv2:/zynthian/zynthian-my-plugins/lv2
Nov 11 17:38:40 zynthian startx[10504]: ++ LV2_PATH=/zynthian/zynthian-plugins/lv2:/zynthian/zynthian-my-plugins/lv2
Nov 11 17:38:40 zynthian startx[10504]: +++ uname -m
Nov 11 17:38:40 zynthian startx[10504]: ++ machine=armv7l
Nov 11 17:38:40 zynthian startx[10504]: ++ â[â armv7l = armv7l â]â
Nov 11 17:38:40 zynthian startx[10504]: +++ cat /sys/firmware/devicetree/base/model
Nov 11 17:38:40 zynthian startx[10504]: ++ model=âRaspberry Pi 3 Model B Rev 1.2â
Nov 11 17:38:40 zynthian startx[10504]: ++ [[ Raspberry Pi 3 Model B Rev 1.2 =~ [3] ]]
Nov 11 17:38:40 zynthian startx[10504]: ++ CPU=-mcpu=cortex-a53
Nov 11 17:38:40 zynthian startx[10504]: ++ FPU=â-mfpu=neon-fp-armv8 -mneon-for-64bitsâ
Nov 11 17:38:40 zynthian startx[10504]: ++ FPU=â-mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mvectorize-with-neon-quadâ
Nov 11 17:38:40 zynthian startx[10504]: ++ CFLAGS_UNSAFE=â-funsafe-loop-optimizations -funsafe-math-optimizationsâ
Nov 11 17:38:40 zynthian startx[10504]: ++ export MACHINE_HW_NAME=armv7l
Nov 11 17:38:40 zynthian startx[10504]: ++ MACHINE_HW_NAME=armv7l
Nov 11 17:38:40 zynthian startx[10504]: ++ export âRBPI_VERSION=Raspberry Pi 3 Model B Rev 1.2â
Nov 11 17:38:40 zynthian startx[10504]: ++ RBPI_VERSION=âRaspberry Pi 3 Model B Rev 1.2â
Nov 11 17:38:40 zynthian startx[10504]: ++ export âCFLAGS=-mcpu=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mvectorize-with-neon-quadâ
Nov 11 17:38:40 zynthian startx[10504]: ++ CFLAGS=â-mcpu=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mvectorize-with-neon-quadâ
Nov 11 17:38:40 zynthian startx[10504]: ++ export âCXXFLAGS=-mcpu=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mvectorize-with-neon-quadâ
Nov 11 17:38:40 zynthian startx[10504]: ++ CXXFLAGS=â-mcpu=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mvectorize-with-neon-quadâ
Nov 11 17:38:40 zynthian startx[10504]: ++ export CFLAGS_UNSAFE
Nov 11 17:38:40 zynthian startx[10504]: + â[â -f /zynthian/config/zynthian_custom_config.sh â]â
Nov 11 17:38:40 zynthian startx[10504]: + cd /zynthian/zynthian-ui
Nov 11 17:38:40 zynthian startx[10504]: + screensaver_off
Nov 11 17:38:40 zynthian startx[10504]: + xset s off
Nov 11 17:38:40 zynthian startx[10504]: + xset -dpms
Nov 11 17:38:40 zynthian startx[10504]: + xset s noblank
Nov 11 17:38:40 zynthian startx[10504]: + true
Nov 11 17:38:40 zynthian startx[10504]: + ./zynthian_gui.py
Nov 11 17:38:42 zynthian startx[10504]: INFO:root:Wiring Layout MCP23017_ENCODERS
Nov 11 17:38:42 zynthian startx[10504]: DEBUG:root:ZYNCODER A: [102, 105, 110, 113]
Nov 11 17:38:42 zynthian startx[10504]: DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
Nov 11 17:38:42 zynthian startx[10504]: DEBUG:root:SWITCHES layout: [100, 103, 108, 111]
Nov 11 17:38:42 zynthian startx[10504]: INFO:root:SWITCHES INITâŠ
Nov 11 17:38:42 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 0 => 100
Nov 11 17:38:42 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 1 => 103
Nov 11 17:38:42 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 2 => 108
Nov 11 17:38:42 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 3 => 111
Nov 11 17:38:42 zynthian startx[10504]: DEBUG:root:ZCTRL âLayerâ: 0 (0 â 2), None, None
Nov 11 17:38:42 zynthian startx[10504]: wiringPiISR: pin must be 0-63 (113)
Nov 11 17:38:42 zynthian startx[10504]: Zyncoder: Zynswitches poll thread created successfully
Nov 11 17:38:42 zynthian startx[10504]: Zyncoder: MIDI tuning frequency set to 440 Hz (8192)
Nov 11 17:38:42 zynthian startx[10504]: + status=1
Nov 11 17:38:42 zynthian startx[10504]: + case $status in
Nov 11 17:38:42 zynthian startx[10504]: + splash_zynthian_error
Nov 11 17:38:42 zynthian startx[10504]: + â[â -c /dev/fb1 â]â
Nov 11 17:38:42 zynthian startx[10504]: + cat /zynthian/config/img/fb_zynthian_error.raw
Nov 11 17:38:42 zynthian startx[10504]: + sleep 3
Nov 11 17:38:45 zynthian startx[10504]: + true
Nov 11 17:38:45 zynthian startx[10504]: + ./zynthian_gui.py
Nov 11 17:38:47 zynthian startx[10504]: INFO:root:Wiring Layout MCP23017_ENCODERS
Nov 11 17:38:47 zynthian startx[10504]: DEBUG:root:ZYNCODER A: [102, 105, 110, 113]
Nov 11 17:38:47 zynthian startx[10504]: DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
Nov 11 17:38:47 zynthian startx[10504]: DEBUG:root:SWITCHES layout: [100, 103, 108, 111]
Nov 11 17:38:47 zynthian startx[10504]: INFO:root:SWITCHES INITâŠ
Nov 11 17:38:47 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 0 => 100
Nov 11 17:38:47 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 1 => 103
Nov 11 17:38:47 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 2 => 108
Nov 11 17:38:47 zynthian startx[10504]: INFO:root:SETUP GPIO SWITCH 3 => 111
Nov 11 17:38:48 zynthian startx[10504]: DEBUG:root:ZCTRL âLayerâ: 0 (0 â 2), None, None
Nov 11 17:38:48 zynthian startx[10504]: wiringPiISR: pin must be 0-63 (113)
Nov 11 17:38:48 zynthian startx[10504]: Zyncoder: Zynswitches poll thread created successfully
Nov 11 17:38:48 zynthian startx[10504]: Zyncoder: MIDI tuning frequency set to 440 Hz (8192)
Nov 11 17:38:48 zynthian startx[10504]: + status=1
Nov 11 17:38:48 zynthian startx[10504]: + case $status in
Nov 11 17:38:48 zynthian startx[10504]: + splash_zynthian_error
Nov 11 17:38:48 zynthian startx[10504]: + â[â -c /dev/fb1 â]â
Nov 11 17:38:48 zynthian startx[10504]: + cat /zynthian/config/img/fb_zynthian_error.raw
Nov 11 17:38:48 zynthian startx[10504]: + sleep 3
Nov 11 17:38:51 zynthian startx[10504]: + true
Nov 11 17:38:51 zynthian startx[10504]: + ./zynthian_gui.py
