Experimental audio to midi conversion?
I saw in the list of technical specifications, “Experimental audio to midi conversion” but looking around in the Audio plugins I couldn’t find it. Where can I learn more about this experimental ability?
It’s not a plugin. You have to enable it from the admin menu. It’s quite experimental and based in the aubio toolset. Don’t expect polyphonic or glissando/pitch-bending detection. You can tweak the command line parameters from the webconf audio options.
BTW, did you already vote in the contest poll?
