Yes, there is where the Surge XT UI should show (in VNC-Engines). Maybe double check that:
- Surge XT is enabled in the Zynthian webconfig / Software / Engines
- an instrument chain was added, with Surge XT an all channels enabled in MIDI Channel
Ok when I checked VNC engines i hadn’t added an instrument chain w SurgeXT with all channels yet. Will try again.
So I’m getting close but I’m having the same issue as @laban77. The MPE enabled state is not loading despite saving a preset and snapshot, then loading custom snapshot.
Here’s what I did:
How do you scan for new presets once you save your custom preset? Is this the step I’m missing before saving snapshot? I’m on a minimal headless setup (Rpi 4 w HiBerry DAC+).
I connected my Pi to a monitor so I can see the Zynthian UI.
In the webconf app under engines I tried ‘search for presets’ but got this err: “Configuring engines failed: ‘Node’ object has no attribute ‘split’”
