Hi @jlearman !
Please, disable the reverb in the clavinet SFZ. All SFZ instruments should be “dry” by default. Reverb should be added later.
Hi @jlearman !
Regarding the Steel Drum SFZ, what is the modwidth parameter? I can’t perceive any difference when changing it.
From the script it should widen the stereo image.
This would of course only work if
Installing Terkelsen’s Marimba I found 2 presets.
I suggest to add some notes about it in description.
Anyway, good job!
Will do.
As @hannesmenzel says, it’s stereo width. I only tested with Sforzando, when I first created it years ago. I’ll double-check on Sfizz/windows and Sfizz/zynth. Thanks for mentioning it. The samples are stereo.
Thanks for the feedback. The -xfade one has velocity crossfades and is the recommended one.
Presets without velocity xfades are to reduce the number of voices being used. On jRhodes, it makes a big difference – when I have a lot of other plugins running I get xruns. But when running just jRhodes, I much prefer the smooth transitions between velocity layers. So, IMHO it’s important to have both.
With steel drum, we rarely play lots of notes at once like we do on piano, so xfade should be the default and either no need for xfade, or make it a keyswitch. I’ll put that on my to-do list. I’ll be sure to update the package info in Webconf accordingly.
Is there a way to document presets other than in the package info?
Not currently.
done
New package: SoulBrass (PR submitted)
Soul Brass section sfz for live keyboard use on Zynthian
Each note plays up to four instruments:
Controls
Each instrument has CC control for
By default, all instruments play at the same volume, with no octave shift. Trombone and trumpet are centered, saxes are panned left and right 45 degrees.
REQUIRED PACKAGES
This repo includes no audio samples. It uses samples from these packages:
Until the package is added, you can install it way:
cd /zynthian/zynthian-my-data/soundfonts/sfz
git clone https://github.com/jlearman/zynthian-soul-brass
Hi @jlearman !
The SoulBrass is already available in the packages list (update your zynthian before).
Could you add this YML file to the SoulBrass repo:
SoulBrass.yml (1.3 KB)
It improves quite a bit the UX in zynthian ![]()
Thanks a lot!
I sent PR:
Merged, thanks! And a good template for next time I need to do this.
The one in jRhodes is much more feature rich.
