thank you so much.
in case you find something wrong, please message and i’ll update and correct
i’m not sure that installing libmicrohttpd-dev is necessary, for example.
by the way, i applied the principle spared no expense
Francesco
Are you familiar with:
Mephisto
a Just-in-Time FAUST compiler embedded in an LV2 plugin
By open music kontrollers
Thanks for the tuto
I’m learning Faust and I’ve made a very simple synth plugin (square_with_delay.dsp · GitHub)
which I managed to build and use on the Zynthian
That’s quite cool!
Be wary though that normally the declare options "[nvoices:8]" is normally enough to make a MIDI-enabled polyphonic plugin, but faust2lv2 (as you suggested) requires you to pass -nvoices 8 when building. A bit weird…
Faust developer here. Reference on the Zynthian platform added here: Powered With Faust - Faust Programming Language
https://faust.grame.fr/community/made-with-faust/#zynthian-platform
gets a not found-404
Does any kind soul know where I might find it? I tried searching for the title text in Faust forum and Google without any actual success although I did find some fascinating rabbit holes to pursue.
New link here: Powered By Faust - Faust Programming Language
Thank you very much! It’s quite an interesting-impressive list.
