hei.
when i “add instrument chain”, i cant see fluid synth anywhere.
i already have done:
webconfig, navigate to Software/Engine and gave the fluid synth a checkbox check (seems to be activated), rebootet, checked if the checkbox is still checked, yes its checked.
I uploadet some soundfonts by Libreary/Presets & SOundfonts/fluidsynth/SD-System
also tryd to directly copy the sf2 files directly on SD-Card (from my linux mint laptop)
then i
looged in with ssh on terminal ssh and removed and reinstalled fluidsynth:
sudo apt remove fluidsynth
sudo apt update
sudo apt install fluidsynth
fluidsynth --version
FluidSynth runtime version 2.3.4
Copyright (C) 2000-2023 Peter Hanappe and others.
Distributed under the LGPL license.
SoundFont(R) is a registered trademark of Creative Technology Ltd.FluidSynth executable version 2.3.4
Sample type=double
rebootet, toggled the checkbox, rebootet again, toggled checkbox, rebootet again.
still no fluidsynth in “add instrument chain” list.
system info:
repo: stable (oram)
Raspberry Pi 4 Model B Rev 1.2
zyncoder: [oram (71de6d2) ]
zynthian-ui: [oram (f43f293)]
zynthian-sys: [oram (a717e49)
zynthian-data: [oram (ddfa009)]
zynthian-webconf: [oram (b530397)]
Build Date: 2024-09-11
Memory: 28% (1089M/3791M)
SD Card: 19% (22G/117G)
Temperature: 54.0ºC
Overclock: [None]
Snapshots: [17]
User Presets: [2]
User Soundfonts: [0]
Audio Captures: [10]
MIDI Captures: [29]
Tuning: [440 Hz]
Master Channel: [16]
Preload Presets: [Off]
ZS3 (SubSnapShots): [On]
Power Save: [10 minutes]
Audio Levels on Snapshots: [On]
i am glueless, any idea?
