Good afternoon!
I can’t run the Zintian V5 kit after the build.
The loading reaches the logo stage. Then the loading stops.
The operating system is running, and so is the network. When you connect the LAN, you have access to the web interface. The terminal is also working. But the graphical shell and the Zynthian environment do not start.
Here is the UI Log, from which I cannot understand the reason:
Restarting UI in debug mode
– Logs begin at Thu 2019-02-14 10:11:58 GMT. –
May 22 08:25:17 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
May 22 08:25:17 zynthian startx[1173]: X.Org X Server 1.20.4
May 22 08:25:17 zynthian startx[1173]: X Protocol Version 11, Revision 0
May 22 08:25:17 zynthian startx[1173]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
May 22 08:25:17 zynthian startx[1173]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
May 22 08:25:17 zynthian startx[1173]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:0A:2D:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait modules-load=dwc2,libcomposite logo.nologo quiet splash vt.global_cursor_default=0
May 22 08:25:17 zynthian startx[1173]: Build Date: 04 April 2023 07:50:56AM
May 22 08:25:17 zynthian startx[1173]: xorg-server 2:1.20.4-1+rpt4+deb10u9 (Debian -- User Support)
May 22 08:25:17 zynthian startx[1173]: Current version of pixman: 0.36.0
May 22 08:25:17 zynthian startx[1173]: Before reporting problems, check http://wiki.x.org
May 22 08:25:17 zynthian startx[1173]: to make sure that you have the latest version.
May 22 08:25:17 zynthian startx[1173]: Markers: (–) probed, (**) from config file, (==) default setting,
May 22 08:25:17 zynthian startx[1173]: (++) from command line, (!!) notice, (II) informational,
May 22 08:25:17 zynthian startx[1173]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
May 22 08:25:17 zynthian startx[1173]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed May 22 08:25:17 2024
May 22 08:25:17 zynthian startx[1173]: (==) Using config directory: “/etc/X11/xorg.conf.d”
May 22 08:25:17 zynthian startx[1173]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
May 22 08:25:17 zynthian startx[1173]: /zynthian/config/img/fb_zynthian_boot.png is 800x480 PNG image, color type GRAY, 8 bit
May 22 08:25:17 zynthian startx[1173]: Zooming image by 100%…done
May 22 08:25:17 zynthian startx[1173]: Merging…didn’t find evidence of prior run.
May 22 08:25:17 zynthian startx[1173]: done
May 22 08:25:17 zynthian startx[1173]: Building XImage…done
May 22 08:25:18 zynthian startx[1173]: ----------------------------------------------
May 22 08:25:18 zynthian startx[1173]: Linux Version: buster
May 22 08:25:18 zynthian startx[1173]: Kernel Version: 5.10.103-v7l+
May 22 08:25:18 zynthian startx[1173]: ZynthianOS Version: 2401
May 22 08:25:18 zynthian startx[1173]: Virtualization: none
May 22 08:25:18 zynthian startx[1173]: Hardware Architecture: armv7l
May 22 08:25:18 zynthian startx[1173]: Hardware Model: Raspberry Pi 4 Model B Rev 1.1
May 22 08:25:18 zynthian startx[1173]: INFO:zynthian_gui_config.: ZYNTHIAN-UI CONFIG …
May 22 08:25:18 zynthian startx[1173]: INFO:zynthian_gui_config.: Wiring Layout V5
May 22 08:25:18 zynthian startx[1173]: ZynCore: Setting-up 20+4 x Zynswitches…
May 22 08:25:18 zynthian startx[1173]: ZynCore: Setting-up Zynpots => 4 x PEC11 …
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = [‘’]
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’, ‘QmidiNet:in_1’]
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = [‘’]
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
May 22 08:25:19 zynthian startx[1173]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
May 22 08:25:20 zynthian startx[1173]: INFO:zynthian_main.: STARTING ZYNTHIAN-UI …
