When using Pianoteq on my Rbpi4 Zynthian, i noticed that the sound quality is not so good as i can hear some noise when i play a note and this noise stops when the note ends.
So i have two questions :
1 - Is there any config to improve sound quality, as i’m using the Pi4 ?
2 - It seems there is a sound gate running all the time, because the sound won’t play all the tail, the gate will cut the note as soon as it reach a minimum level… Where can i find this gate settings ?
I just added a feature request to disable auto mute by default. I just bought a new amplifier (because my old had died) and whilst testing I heard horrible crackling at the end of each note from the Zynthian. I suspected a fault with the new amp but tracked it to the auto mute (gate) performing terribly on Hifiberry DAC+ADC Pro which is really noise at the end of each note.
I am not able to disable auto mute from ALSA mixer and changes made from webconf (which do work) do not persist a reboot.
