I am looking at the Zynthian but before buying I would like to know if it is the right tool for me.
I would like to emulate different General MIDI sound modules (SC-55, SC-88, etc) using SF2 SoundFont to use with retro games and easily switch between them.
The connectivity would be something like that:
PC -> Roland UM-ONE mk2 or Sound Card MIDI interface -> Zynthian V4.1
When looking at the Zynthian user guide / youtube video it seems that for using SF2 I need to use FluidSynth synthesizer. But it seems that I need to manually choose the instrument for each MIDI channel.
Is it possible to use the Zynthian as a General MIDI sound modules?
Yes ! You will be able to feed zynthian with midi data comming from your PC using your Roland um-one midi interface or with any kind of midi hardware (keyboard, midi sequencer, drum pad …) though USB or the classical midi connector.
I haven’t used my SoundCavas since building a Zynthian. You need to add an instant of Fluidsynth for each MIDI channel loading a GM soundfont (provided) and select multitimbral mode then you can play it just like a GM device. Instruments can be selected by Program Change. Fluidsynth built-in reverb and chorus can be used and you can add extra effects from the large selection of LV2 plugins.
